Results 1 to 11 of 11
    Aug 2015
    Default Doing a micro eeprom the hard way
    2014 Toyota Hiace van
    Jun 2016
    very hard way , you can do this on board also then why you use 2nd base
    mecjp's Avatar
    Oct 2013
    other world
    take a pogo pin and make you and adapter to your base....
    sharing is the key of success
    mecjp's Avatar
    Oct 2013
    other world
    Quote Originally Posted by mecjp View Post
    like this is more easy and clean!
    XmoDDeR's Avatar
    Mar 2011
    putting salt on leeches, one grain at a time!
    i can mke tht alot nicer
    Reading is fundamental, asking is easy............................
    hcip's Avatar
    From the heaven of paradise in the middle of happiness|hobby:__Bedtime| Sex:Female|Status:Not_Virgin
    Quote Originally Posted by XmoDDeR View Post
    I connect it on the Via Holes with Pogo pins, no soldering and no removing of EEPROM...
    Stupidity is not a disease, because there are no existing hospitals for Idiots!
  7. The Following 3 Users Say Thank You to hcip For This Useful Post:
    automotrizVIP (21st January, 2018), JammerOne (21st January, 2018), pongsky (22nd February, 2018)
    clusters's Avatar
    Mar 2015
    Canada
    Quote Originally Posted by hcip View Post
    Yes, but you are smarter than the average button pusher.
  9. The Following User Says Thank You to clusters For This Useful Post:
    hcip (21st January, 2018)
  10. #8
    mecjp's Avatar
    Oct 2013
    other world
    what you do more nicer than a pogo pin?
  11. #9
    super jumbe's Avatar
    Livingstone
    Any one got wiring pinpoint for 2013 Honda Jaz dash eeprom 93c76 this is a very small eeprom?
  12. #10
    May 2011
    hi
    some has kia carnival or sedona with tiny eeprom of c66 contact points ....thanks or power up pins...thanks
  13. #11
    hcip's Avatar
    Quote Originally Posted by digimile View Post
    hi
    To Get the Power pins(in all Dash)
    1: You need a multimeter (Ohmeter) set to X1
    2: look for the bigest Electrolytic capacitor in Culster PCB
    3: in positive side of the electrolityc capacitor, there is a Diode connected to it ( Reverse votage Protection)
    4: Check the Diode connectivity (anode side) to Cluster pin socket, (that is the positive supply of cluster)
    5: Negative side is easy to find, in the Ground side of PCB measure the continuity of it to the cluster socket to find the negative supply
    See the attached picture for reference
  14. The Following 12 Users Say Thank You to hcip For This Useful Post:
    Berubeg (21st January, 2018), digimile (21st January, 2018), fes_786 (21st January, 2018), gijsvm (29th January, 2018), H.Wessel (21st January, 2018), JammerOne (21st January, 2018), Johnner (21st January, 2018), kimoe (21st January, 2018), Nikola1309 (4th May, 2018), pongsky (22nd February, 2018), scotlock (28th January, 2018), Shakeelbhugeloo (3rd March, 2018)
