Results 1 to 4 of 4
Hybrid View
    Member accies's Avatar
    Nov 2008
    Default Zgemma H5.2TC looses network connection.
    Box is set up for cable but freezes often. It seems that it looses network connection. Press blue button and network it says not connected to network. A restart doesn't work most times,have to wait and keep trying. All other devices still work tho. Is the box Donald? Or on the way out?
    DK Veteran lincsat's Avatar
    Jun 2008
    If it's not connecting to your home network, then most likely a cabling problem or an issue with your Router/settings
  3. The Following User Says Thank You to lincsat For This Useful Post:
    accies (20th January, 2018)
    Newbie SLICK181818's Avatar
    Jun 2011
    orion constallation
    Hi accies I had vm guys out and they put the problem that I suffer like yours down to software issue, on mk 2 and 3 routers and are waiting for a new update for routers nation wide, this was in middle of jan so hopefully soon . ps they replaced cable to house and rooms checked the street box all ok
  5. The Following User Says Thank You to SLICK181818 For This Useful Post:
    accies (12th February, 2018)
  6. #4
    Nov 2008
    Thanks for your info. Some days it's fine others almost unwatchable. Il see if any updates are available or put my old router back on.
