post dump ...........
hello,
I have Nissan sunny with 93c66 and 1307789 km try to read it with digimaster and digiprog but selecting what ever model it shows different km by tool.is that means cant we manually change its value by these tools instead of posting dumps here?
im not good with hex editing so is there anyway to solve this kind of issues?
br.
sum444584 (20th January, 2018)
thank you sir,
but need any stand alone method or calculator for this.otherwise each-time odo comes I have to run over here!!
I have ordered
UPA USB Programmer V1.3 is there any scripts to work with this programmer to adjust millage?
thank you
no I did it after remove and connect it into OBP adapter of digimaster and did same for digiprog.select automatic selection and manual selection 93c66 but it displayed wrong millage value.anyone know any other reason for this?
https://www.youtube.com/watch?v=k4EaHt7-Hlw
can someone describe this which software use for edit km in here? can we do this with carprog 10.5 clone? I think this method we can adjust any km by our selves.right?
please describe this in English and which other tools we can use for same process?
br,
Just desolder eeprom from dash, then use digiprog and select nissan terrano 93c66 to change mileage in your sunny, that´s all
right now i have digimaster at with me. yes i select nissan terrano 93c66 but it shows low km than original!!
i have past experience with try to adjust same situation odo finally only showed ------ on its lcd!!
original millage is 130789km
digimaster showing millage is 130326km
i attached both format file read from digimaster.someone tell me why this happen??
this dump nissan fb15 not 14
this is normal.
just write mileage you want and you be ok.
sum444584 (21st January, 2018)
thanks for help m8s,
br
hello m8s,
can someone help me to adjust millage Mahindra Maximo.dash has microchip pic16f946 and 8pin small ic but cant see its numbers...
any master doing this cluster? i guess 8pin small ic might be eeprom ..how to read this cluster.??
have upa-usb 1.3,digimaster ,digiprog
need help m8s
br
Nothing will remain in this World , Everything will come to END!
THINK POSITIVE NOTHING IS IMPOSSIBLE
Please do not spam by PM asking for help. Use forum, that is why we are here.
