bad configuration, or electrical damage in donor bsi
Hello, I have a problem with a BSI of a citroen c3 1.4 hdi ref : F02.00 9646775180. the old bsi is oxidized but the car start and stop normaly but there are some options that do not work, I took exactly the same bsi, I virginized, recode with lexia exactly like the old. but what happens is that when I take the ignition off the dash stays on and the car does not stop. have you ever had the same problem. I tried several bsi but still negative BEST REGARDS
bmw for ever
My English is little bit bad, but day after day is better. Like my experiences https://www.youtube.com/channel/UCdT...bx2Pc7WI4pWUWA
My help not for free, press THANKS and REP, for make me HAPPY
im not using passwords, my work is for this forum and members free
Masterprog (22nd January, 2018)
no i try 3 other bsi today and same problem, the old work good but the new no
bmw for ever
you make virgin, try copy old bsi data to new, no make virgin. (i think must be data, if make on three bsi same problem)
Have you right bsi? (hw sw)
hello i do it but that not change
bmw for ever
Try communicating with lexia to see when you close the ignition,does it read closed switch??
Check you have correct bsi. Try and match numbers up. Normally this fault is with under bonnet fuse box when ignition will not turn off.
Stelaras26 (30th January, 2018)
Try to hold brake pedal and the same time put the igniton off.
Is the motor stops ?
