Help
I have Legacy with new Engine computer, all other components are original.
Engine ECU was stolen so customer bought brand new ecu. Car not starting.
Help
bobby maze (20th February, 2018)
2009 Legacy
Engine 93C56
BCM 93C56
Smart Key system 93C86
Hi Elias here are my BIU and ECU readings as discused...
Many thanks...
Hi Elias sorry forgot to give you the ECU dump c56 the other files were the BIU 24C02 reading...
Here is the ECU reading...
bobby maze (18th February, 2018), Tomultimate (28th February, 2018), Wilber Pardo (8th October, 2019)
Hey Eliaselias are you able to help me with the 2009 Legacy i posted the dumps here already.
hello elias
i fallow a bit of how you helped others and was wondering if you can help me as well
i have 2 subaru impreza 2012 im working on and i think its the same as the others here code P1571 is also coming ON on both
i atteched both BIU and ECM x2 dumps
if you can help me that would mean a lot
thanks in advance
maestro por favor ayuda
herencia, DTC: P1571. llave de proximidad , año 2007 , japon,.
bcm 24c01
ecu 93c66 HITACHI
bobby maze (20th February, 2018), drugowaz (20th February, 2018), taxo1965 (16th November, 2019), Wilber Pardo (8th October, 2019)
elias you are number 1 my friend it worked thanks again for helping it means a lot
eliaselias (20th February, 2018)
Hi Elias subaru impreza 2009 .smart ecu 93c86 88801fg000 and bcm 24c01 88281fg740 . The bcms been wiped ,hit write instead of read ,can you make a new dump for bcm off remaining dumps is it better to start again with a virgin dump ?If so could I have a virgin dump?
eliaselias (21st February, 2018)
Hey Elias,
Im having difficulites with engine computer and BIU link for 2012 G key system. Any chance you can have a look at these file and work your magic? Body contol accepts keys in and out, but the linkage of engine ecu doest seem to work. Comes up with p1571. No other fault codes. i have attached files from BIU and engine ECU. 24c02 and 95c56. Best Regards - Tom
Engine ECU 22765AE720
Body control 88281FJ420
Key in the ignition, turn to start. G key Sysytem
IF MY POST WAS HELPFUL DON'T FORGET TO GIVE ME LIKE AND REPUTATION... THAT WILL KEEP US HELPING OTHER'S
