IF MY POST WAS HELPFUL DON'T FORGET TO GIVE ME LIKE AND REPUTATION... THAT WILL KEEP US HELPING OTHER'S
godfathertre (5th December, 2018)
This is information what i did, how repair this problem. Please don't forget give me reputation. Thanks
eddieddi (12th January, 2019), key mechanic (4th March, 2022), mark1313 (14th March, 2023)
alex_r_2001 (3rd December, 2021), Anydraj (26th December, 2022), eddieddi (12th January, 2019), electronicdeivi (30th May, 2020), lock66 (13th November, 2020), narkeleptk (31st December, 2018), Rjautolocksmith (31st December, 2018), sinanorhan (5th October, 2019), Weasel3 (30th December, 2018)
You reaied it yoursef by not knowing what your doing? Dont be funny ok. Somebody done it for you and youre know writing here as revenge to get reps?
eliaselias (31st December, 2018)
DO NOT LIE... WHERE I ASKED YOU FOR 200 EURO ? DO NOT TALK TO JUST TALK ... YOU CAN ASK OTHER MEMBER
ANYWAY THIS IS NOT CORRECT SOLUTION BECAUSE THE HEX ARE TOTALLY DIFFERENT IN BOTH DUMP AND YOU HAVE CHANGED IMPORTANT DATA IN BCU AND ECU...
NEVER MESS WITH DATA THAT DON'T NEED CHANGE
MY SOLUTION CORRECT THE SAME BYTE DATA WITHOUT CHANGING ANOTHER SETTING IN ECU AND BCM..... FOR YOUR INFORMATION DATA IS CORRECTED ONLY IN 1 ECU AND NOT IN BOTH
ANYWAY GOOD LUCK
SORRY BUT YOU DON'T EVEN KNOW ANYTHING ABOUT SUBARU SYSTEM
alex_r_2001 (3rd December, 2021), autochei (7th January, 2019), drugowaz (31st December, 2018), jomberykaso (26th September, 2019), lion0304 (14th January, 2019), rateb76 (8th January, 2019)
All data is corrected because i was used for repairing SSM4 for subaru. That is set for subaru auto. When SS4 repaired i read all datas from memory Dashboard, Bcu, and ecu. If somebody has a problem with repairing i can help for free.
Hello Eliaselias,
i have a problem with Impreza 2012 1.6 .. no sync as all people ..
IBU dump is attached .. i'll appreciate your help
Last edited by rateb76; 7th January, 2019 at 03:52 PM. Reason: add attachment file
Eliaselias Solved the Problem ... you are the man ..
tried every thing Possible using SSM and many aftermarket Devices without Success ..
Many Thanks Eliaselias
eliaselias (8th January, 2019)
autochei (8th January, 2019), drugowaz (8th January, 2019), trinicolin (8th January, 2019)
That is wrong solution. Trust elias he knows
eliaselias (10th January, 2019)
I am not questioning the fact that elias knows what they are doing. They clearly do.
My question is for rateb76 and if they (or anyone else) tried the information provided by pifer2004 and if it was successful or failure. I dont need this work done I am just curious
eliaselias (13th January, 2019), narkeleptk (11th January, 2019)
