Page 6 of 10 FirstFirst 12345678910 LastLast
Results 76 to 90 of 150
  1. #76
    Jul 2018
    Milky Way
    ssm4.jpgThis solution was repaired by ssm4. After repaired i read again and that is this files.
  2. The Following User Says Thank You to Piter2004 For This Useful Post:
    narkeleptk (13th January, 2019)
  3. #77
    Jun 2018
    thank you for you help elias, here are the files
  4. #78
    Aug 2015
    BEHIND YOU
    Quote Originally Posted by mattyman007 View Post
    here is your magic file that will make your car back to life again
    IF MY POST WAS HELPFUL DON'T FORGET TO GIVE ME LIKE AND REPUTATION... THAT WILL KEEP US HELPING OTHER'S
  5. #79
    Jun 2018
    Thank you bro, you are the man!! Worked perfect
  6. The Following User Says Thank You to mattyman007 For This Useful Post:
    eliaselias (24th January, 2019)
  7. #80
    Feb 2014
    Default subaru emreza 2014
    HI ALL HERE i have subaru impreza with all lost key ma try to program key with skp900 but still not working now am ready immo data using tango to load that file but tango say unknown version ,,,can some one help me to check my file if there is a something wrong ...thanks
    ecu part n.22765AF262,,112700-4302 ECU EEP 93C56B
    IMMO PART N.88281FJ121 24L02
  8. #81
    hcip's Avatar
    From the heaven of paradise in the middle of happiness|hobby:__Bedtime| Sex:Female|Status:Not_Virgin
    Quote Originally Posted by husseintamimu View Post
    Bad BCM dump............
    Stupidity is not a disease, because there are no existing hospitals for Idiots!
  9. #82
    Feb 2014
    okay can you help to repair that data and check for also this cluster data..thanks
  10. #83
    hcip's Avatar
    You need to program 2 keys to BCM before we can calculate CRC to Dash,
    You can try this two paired dump, write Key in Key1 & Key2 using tango and post the BCM dump here save by Tango, I will try to married it in your dash
  11. #84
    Feb 2014
    Quote Originally Posted by hcip View Post
    i use lkp2 to programm ..
  12. #85
    hcip's Avatar
    Try it, I hope it wil work
  13. #86
    Feb 2014
    thnks let me try i will report ,......
  14. #87
    Feb 2014
    hi hcip am try to start a car but immo light stay on when i pun ignition on and it has two fault code ,,,,,,P1571 THIS IS CURRENT AND P1574 THIS IS HISTORY THERE IS ANYTHING I CAN DO HERE??
  15. #88
    hcip's Avatar
    The file is not compatible to each other, The main problem is your original file from BIU was damaged and we cannot repair it
    You need a good paired dumps from DASH,ECU & BIU and do allkeylost to start the car,
  16. #89
    Aug 2015
    BEHIND YOU
    here is your magic file that will make your car start again with 100% testable solution
    good luck
  17. The Following User Says Thank You to eliaselias For This Useful Post:
    husseintamimu (19th February, 2019)
  18. #90
    Feb 2014
    Quote Originally Posted by eliaselias View Post
    good luck
    THANKS HELP PASS PLS AND I CAN USE LKP-2 TRANSPONDER TO START THAT CAR??
