SUBARU XV2012 stop working
Page 1 of 10 123456 ... LastLast
Results 1 to 15 of 150
    Aug 2010
    Default SUBARU XV2012 stop working
    Hello
    i am helping my friend he got this car after another one locksmith tried to add key to it and the car stops working (even customer original key ) ,its a 2012 SUBARU XV.
    I tried every tool I have G scan ,T code and so on I did even add anther G chip to it by tango memory 24c02 in the BCM but the car is the same.
    the key is programed in the BCM but the immo light will go off and back on again .
    I did not find any solution after looking in the net every where , the BCM and ECU they lost synchronization ,evry one says U have to send the car to SUBARU dealer and we don,t have one hear.
    P1571 is in the ECU
    ANY ONE CAN HELP
    THAN,K U
    nickolasd's Avatar
    Nov 2015
    is far is i know bcm(BIU) gets synchronized with cluster. looks like dump was damaged. find another used bcm add key via dump and sync with cluster via dump, I'm sure somebody can help with that here.
    or find dump out of the same bcm part number do key and sync.
    i have one dump out of 13 XV may be it will work for you. post your part number.
    when you send car to subaru dealer they remove bcm and cluster and send it somewhere to reset to a brand new state.
  3. The Following User Says Thank You to nickolasd For This Useful Post:
    wd bau (23rd January, 2018)
    Aug 2015
    BEHIND YOU
    Quote Originally Posted by wd bau View Post
    Hello
    P1571 is in the ECU
    ANY ONE CAN HELP
    THAN,K U
    hello post dump for bcm
    i will solve your problem
    IF MY POST WAS HELPFUL DON'T FORGET TO GIVE ME LIKE AND REPUTATION... THAT WILL KEEP US HELPING OTHER'S
  5. The Following 3 Users Say Thank You to eliaselias For This Useful Post:
    bobby maze (18th February, 2018), varnas34 (9th July, 2018), wd bau (23rd January, 2018)
  6. #4
    Aug 2010
    thanks a lot ,ok i will read them and post here
    Aug 2010
    Quote Originally Posted by eliaselias View Post
    hello post dump for bcm .... and dump for ecu...
    here ECU and BCM dump
  8. #6
    Aug 2010
    Quote Originally Posted by nickolasd View Post
    here BCM #88281FJ200 with Eprom 24c02
  9. #7
    Aug 2015
    BEHIND YOU
    just write this new file and your car will be started with all key
  10. The Following 11 Users Say Thank You to eliaselias For This Useful Post:
    aleppo007 (9th May, 2019), bobby maze (20th February, 2018), dritan (1st February, 2018), drugowaz (28th January, 2018), key4man (6th February, 2018), kronk92 (1st February, 2018), Mohammedananew (1st August, 2018), phuckyall (14th November, 2018), wd bau (24th January, 2018), wheepy (23rd June, 2020), Wilber Pardo (8th October, 2019)
  11. #8
    Aug 2010
    thanks elias for help car start .
  12. The Following User Says Thank You to wd bau For This Useful Post:
    eliaselias (28th January, 2018)
  13. #9
    hi elias l have same problem on subaru 2013 impreza can you help me please thanks in advance l have AutoProPad original and no work thanks in advance
  14. #10
    Aug 2015
    BEHIND YOU
    Quote Originally Posted by pimpin View Post
    Read and post your dump
  15. The Following 2 Users Say Thank You to eliaselias For This Useful Post:
    bobby maze (20th February, 2018), drugowaz (1st February, 2018)
  16. #11
    Hello im am having similar issues with a 2012 subaru impreza Japanese market car came to me after the guy removed cluster for non-working fuel gauge. Would not start after it seems someone not knowing tried to reprogram keys with some unknown to me key programmer, I am getting p1571 in ECU, Whenever i try to do immobilizer registration it fails. Please advise me how to read Dumps i have a TL866a Programmer and Clone SSMiii.
    Thanks For any Help in Advance
  17. #12
    Aug 2015
    BEHIND YOU
    Quote Originally Posted by skemotor View Post
    read bcm data and send it here
  18. The Following 3 Users Say Thank You to eliaselias For This Useful Post:
    bobby maze (20th February, 2018), rateb76 (7th January, 2019), Wilber Pardo (8th October, 2019)
  19. #13
    remove bcm located in driver side...up the pedal break and read for me eeprom 24c02
    here is the picture of the eeprom location... sometime the eeprom is micro small...i suggest you to read it outside circuit
    Attachment 504765.....
    then remove ecu from passenger side... and find inside it 93c56 or 93c86... read eeprom and send me the data...
    Attachment 504769
    do you still have old dashboard if yes let me know.... ( dont need to read eeprom of dashboard)
    Here are files
  20. #14
    Aug 2015
    BEHIND YOU
    Here are files
    here is your file that will make your car start
  21. The Following 4 Users Say Thank You to eliaselias For This Useful Post:
    kachimbi (19th September, 2018), Mininoob (25th September, 2019), taxo1965 (16th November, 2019), Wilber Pardo (8th October, 2019)
  22. #15
    Thank you Elias car Starts your a genius
  23. The Following 2 Users Say Thank You to skemotor For This Useful Post:
    eliaselias (21st February, 2018), Wilber Pardo (8th October, 2019)
