PASSAT B5 2.0TDI EGR PROBLEM
    Apr 2012
    London
    Default PASSAT B5 2.0TDI EGR PROBLEM
    Hi Fellows!
    Passat B5 2005yr 2.0TDI 100KW EDC16u31
    Got a car with issue - no power (limp mode) - no error codes stored in ECU. But car had DPF OFF and EGR OFF made by other workshop.
    I assume that egr was disabled not correctly and there is no visible errors becuse ECU has switched off errors related to EGR.
    As a result for day or two car runs ok -(many cycles of warming and cooling) no problems at all - live data ok with turbo, inj.timming and injector corrections. Then car is switching to limp mode and no errors stored in ECU -when I'ml erasing non existing errors car runs ok for a short time then limp mode again.
    Could You check if map taken from ECU has proper egr off solution - histeresis mods on each egr map and so.
    any suggstions appreciated
    Thank You
    map with DPF OFF and EGR OFF attached.
    macako6's Avatar
    Mar 2015
    try and report how it is
  3. The Following User Says Thank You to macako6 For This Useful Post:
    zyjekrc51 (22nd January, 2018)
    Apr 2012
    London
    Quote Originally Posted by macako6 View Post
    Thanks, could You send pass for file
    cheers
    Mike
    macako6's Avatar
    Mar 2015
    First, empty the private messages
    Apr 2012
    London
    I have made some room on my PM
    Apr 2012
    London
    ok. I have made a few corrections in hysteresis maps on file from first post and works ok for now.
    thx. closed
