Page 1 of 2 12 LastLast
Results 1 to 15 of 17
    jodge's Avatar
    Mar 2017
    Default Alfa 166 remote questions
    year 2003 this kind of key
    I can't program the remote with sbb or alfaobd bcose the pin is wrong. They have the original keycard. And according the alfaowners forum the remote and the immobox are seprated and they are using different pincodes.
    The codecard contains only the immo and the mechanical code. If this separted pin thing is real there is any solution to read the remote pin code (obd or with soldering job) or any alternative solution to program the remote w/o pincode?
    thx
    Sir, are you classified as human? Negative, I am a meat popsicle
    Top Poster dooshan's Avatar
    Mar 2012
    Belgrade
    In my experience,no. Always obtained from dealer. If I’m wrong,can wait to find out
    jodge's Avatar
    Mar 2017
    Quote Originally Posted by dooshan View Post
    I made some research
    If you have one working remote:
    1.
          Arm and disarm the alarm sixteen times or until the alarm stops responding, alarm now in program mode.....
       2. Once in program mode press the button of the new remotes(s), press  the button of the original remote(s). This must be done within 8  seconds of each action. If 8 seconds pass without any actions the alarm  will automatically exit programming mode and you will have to start from  step 1.
       3. Wait 8 seconds to exit learning mode.
       4. Test remotes.
    Otherwise you need the remote code.
  4. The Following User Says Thank You to jodge For This Useful Post:
    dooshan (21st January, 2018)
    Mar 2012
    Belgrade
    Quote Originally Posted by jodge View Post
    1.
       4. Test remotes.
    Try and report
  6. #5
    newone's Avatar
    Oct 2016
    you can check here,there is a guy how can give remote pin by vin http://www.digital-kaos.co.uk/forums...meo+156+remote
    also you can read here
  7. The Following User Says Thank You to newone For This Useful Post:
    jodge (21st January, 2018)
  8. #6
    jodge's Avatar
    Mar 2017
    Quote Originally Posted by newone View Post
    i see now i have to expand my search criteria next time.
  9. #7
    jodge's Avatar
    Mar 2017
    Try and report
    not working
  10. #8
    Mar 2012
    Belgrade
    not working
    Yeah...
    Every time when I took this problem to solve,each time was only in situation where remote did work for sure but stopped mainly after absences of power for few days...because then I can only focus on PIN,not water/installations issue. With some I had success,and with some I hit the wall.
    Anyway...dealership,PIN by VIN
  11. #9
    Aug 2015
    you need to read memory of remote recevier unit, on 156 it is HC05B16 it should be same on 166 but i am not sure.
  12. #10
    Mar 2014
    West Sussex UK
    Quote Originally Posted by dtip View Post
    No it’s not the same 156 has Siemens receiver with 0D60J. 166 has trw receiver with 93c46 similar to Fiat Multipla
  13. #11
    mikajna's Avatar
    Mar 2015
    Or maybe Ducato, ducato also have TRW key, and in receiver is 93C46...
  14. #12
    Jul 2016
    UK
    Anyone been successful in reading the pin from one of the TRW 93c46 units?
  15. #13
    HeXeN's Avatar
    Mar 2015
    Alfa 166 - Anybody tested this website to calculate code from dump?
    http://theozaurus.com/projects/n67_dump_decoder.html
    http://theozaurus.com/projects/n67_hardware.html
    Can I reuse black flip 2 button remote instead of the red one?
    Is this manual procedure to program remote or via obd? (like alfa 156 - I use CK100)
  16. #14
    Sep 2016
    You mean 1 button remote from Alfa like 145? As I understand 166 use two different generation of remotes. Link looks be related to early one.
  17. #15
    HeXeN's Avatar
    Mar 2015
    NO. I mean 2 button. look picture
