Results 1 to 13 of 13
    Jan 2017
    Default VOLVO S80 CEM Pincode Dump TB28F400B5B
    Hello.
    I want to know if someone can help to get pincode. I have no any program to get pincode for volvo Dump.
    Thanks in advance.
    Jul 2011
    what do you want to do?
    Volvo Electronics Enginering
    CEM Config change, virginize modules , keys programing...
  3. The Following User Says Thank You to Tomanio For This Useful Post:
    cosmiko (22nd January, 2018)
    MartiLer's Avatar
    Dec 2016
    CEM dump you read wrong. Its damaged
  5. The Following User Says Thank You to MartiLer For This Useful Post:
  6. #4
    Jan 2017
    And this Dump is ok???
    I want to make a new key and program remote.
    MartiLer's Avatar
    Dec 2016
    no..........
  8. The Following User Says Thank You to MartiLer For This Useful Post:
  9. #6
    Jan 2017
    I read with VVDI Prog and if i use this file with VVDI2 is ok, no damage dump tell me. Are you sure both files are damaged dump???
  10. #7
    sure - dumps is bad !!
    you dont have contact on some pins - read on good programmer like beeprog, xeltek, labtool...
  11. The Following User Says Thank You to gif_kuba For This Useful Post:
  12. #8
    Jan 2017
    And now if i read with vvdi prog, and make a key with vvdi2, and write again the file, how can i get good dump?? Maybe now i write bad dump and now i couldn't get good dump
  13. #9
    Top Poster dooshan's Avatar
    Mar 2012
    Belgrade
    bruh...If you'r 1st reading was bad,and you used this dump to make image file and wrote it back...you f... up original file...no good dump no more
  14. The Following User Says Thank You to dooshan For This Useful Post:
  15. #10
    Jan 2017
    And now i broke CEM motherboard too. Now i don't know how can i solve it. Now i need to get one new or used CEM and the original file, but i don't know how can i do it. Can anyone help me to fix that????
  16. #11
    MartiLer's Avatar
    Dec 2016
    try to warm up with a hairdryer and count 28f400.
  17. #12
    Jul 2011
    if you havent got original not corrupted file and config of the car is corrupted only way is to write config manualy or reload CEM.
  18. The Following User Says Thank You to Tomanio For This Useful Post:
    cosmiko (23rd January, 2018)
  19. #13
    Jan 2017
    How can config manualy or reload CEM???? I found a program that with ECU and CEM dumps can make new files together and make new transponders, does it work for that?? I mean, if i got a used CEM maybe i can do it.
    Thanks for your time.
