ford EEC-VI
Results 1 to 5 of 5
Thread: ford EEC-VI
    May 2010
    Default ford EEC-VI
    What tool can read/write this ecu on bench. I found only kess v2 by obd can do itd.
    what kind of flash and processor is inside?
    ecu is: 6S61-12A650-XB from fiesta ST
    Jun 2013
    EU
    Be carefull, even original kess tends to brick that ecu. Then is a nightmare to recover. MPC5xx processor, bmd tool needed, but no info and no visible bdm pads. So... you are warned
    Dec 2015
    Done 6 car by obd kess 5.017 no problem
  4. The Following User Says Thank You to amcharge For This Useful Post:
    morfej (23rd January, 2018)
    morfej's Avatar
    Dec 2008
    Perhaps 5.017 has fixed protocol for that ECU. Have seen spmething like that on renault EDC16CP33 ... same ecu older kess can read and write just fine, after 2011 for example only the fixed protocol (in 5.017) can read and write it.
    br
  6. #5
    Jun 2013
    EU
    I talk of bricked using original kess and alien people washed hands.
    Told to recover by vcm ids but the brick was total, no comms, had to replace ecu finally and match with vcm ids.
    And flashing process went smooth, no errors, just after remove key and put again... dead ecu.
    Very unstable obd protocol for that ecu even with ori tool. Just that.
  7. The Following User Says Thank You to morgano For This Useful Post:
