kess v2 and trionic 7 ECU saab 9-5
Results 1 to 3 of 3
    Jan 2018
    shaftesbury,Dorset,UK
    Default kess v2 and trionic 7 ECU saab 9-5
    hello today I have tried to map a saab 9-5 with a map already on my computer , original car HW and soft ID was different from the mapped file one and evrey time i try to write with kess it said protocol not supported. however now I see hw and soft and ecu ID is different is this why kess failed? I have now transffered the maps from the file into the original read from the car now all matched up will it work when i try tomorrow?
    quick question did kess tell me protocol not supported because it detected write file different ecu and numbers? thanks guys had my head scratching about this today as I know kess works well for trionic 7 ecu
    Ignasvw's Avatar
    Feb 2016
    Lithuania
    It means that you choosed wrong ecu, or model.
    Chiptunning / EGR / DPF / FAP / DTC / FLAPS / Adblue / ETC.... CUSTOM SERVICE / FILE SERVICE / 24/7 Support
    Jan 2018
    Quote Originally Posted by Ignasvw View Post
    it writes correctly when open sid hasnt been touched or any information not located in the map section of the file... is there any way to get kess to write full ecu, as it read the full ecu file just fine... recovery option??
