If i make a transponder from eeprom for renault twingo. will it start?
Results 1 to 8 of 8
    Question If i make a transponder from eeprom for renault twingo. will it start?
    The old Renault cars (Megane Scenic, Twingo, Clio, Kangoo) All work with that plipkey immobiliser,
    you need to use the remote to get the immo deactivate.
    But i can also create a transponder from the eeprom.
    I never tested it, but is it possible, that if i open the car manualy, and use the transponder+key, the
    immo get off?
    Or if i clone the plipkey with something like Silca RW4 or Keyline mini or Megacopy, will it work without the plipkey?
    Aug 2015
    There are old renault immobilisers that are activated/deactivated via infrared remote ONLY , those are usually before 1998 , like megane , scenic, clio pre 1998. You can't make transponder for them as they don't work like that, they don't read any traponder and even don't have coil on ingition lock for it, only solution is deactivating immo using INFRARED remote, entering pin code manually for emergency start or immo off.
    Same renault cars after 1998 have tranponders and you can make transponder from eeprom and start the car, their remote part is RADIO controled and it used just for remote locking/unlocking as usual cars.
    So answer is if car is using infrared remote you can't make tranponder for it and start it
    Seen this before?
    Aug 2015
    Quote Originally Posted by albertros View Post
    Seen this before?
    What that have to do with his question about how infrared remote immobilisers on renault works? or am i missing something?
    Today i had a Renault Twingo 2001 1.2 with remote as immo.
    Remote died, and i made a T5 transponder with Zed-full via Eeprom.
    And it works. So there is a way :-D
    Quote Originally Posted by dtip View Post
    I didn't read you'r answer well.
    You are right. The Twingo i did was RF not IR..
    So.. immo-off is the only solutions for this.
    Aug 2015
    Quote Originally Posted by bero View Post
    To be short - renault with RF uses transponder as immo , renaults with IR uses IR remote as immo and only IMMO OFF or make new IR REMOTE.
    Thats true.
    I never made a new key for it, normaly i ordered new keys from dealer bij VIN and only need to sync.
    BUT.. they don't sell them anymore.. no stock.
    So is there a way to make them?
