Are these from the same company? As in do they offer the same remote coverage on both devices? kd900 dropped tokens right? Does mini kd use tokens or is it free to program remotes once you have the cable?
Might just get mini kd if the're the same and wait for new KD-X that was just announced.
darknezz19 (22nd January, 2018)
URG200 too.
ramiz auto lock (27th January, 2018)
Hi, I wanted to know if you have experience with Mini KD
Once I have generated the remote control then how does it work to start the car?
The Mini KD also creates the transponder?
Thank you
All KD programmers work the same way - choose what you need and generate it. If it is supposed to be with transponder like the PSA keys then you must use a transponder blank remote like the NB series. If not then B series. After that yoo program like an original key or remote.
KD is not a magic tool that takes away the need to invest in diagnostics , it takes away the need to stock a few hundred different remotes allowing you to make hundreds of different remotes from a single virgin remote . you still need other equipment to program the remote to the car just as you would with an oem key.
so KD will not generate the chip to start the car and it will not code the remote to the car either . it just prepares the correct remote ready for programming with other kit
so in answer to your question , to make it work to start the car you need the correct diagnostic programming equipment to then code it to the car.
kronk92 (29th January, 2018)
