how can done keyless remote for mk6
Results 1 to 15 of 15
    Jun 2014
    Default how can done keyless remote for mk6
    Hi, i buy some remote used OEM but refurbishing by new transponder for mk6 with keylessgo entry. so did any one have idea if this remote after programming can work it self the keyless function? or i must adapt by 09 module the lock unlock by diagnostic tool?, thanks in advance...
    topclef's Avatar
    no separate procedure for keylessGo , remote will work after transponder programming , if you replace Megamos id48 , remote will not work .
    you have two choices in the morning: go back to bed and continue dreaming, or you get up to make your dreams come true
  3. The Following User Says Thank You to topclef For This Useful Post:
    pouleddy (22nd January, 2018)
    newone's Avatar
    Oct 2016
    remote will adapt by itself when you program key
  5. The Following User Says Thank You to newone For This Useful Post:
  6. #4
    Jun 2014
    Quote Originally Posted by newone View Post
    can you explain me how it done? cause i buy it refurbishing by new transponder, just i want to be sure if it done by learn key or after must have any procedure to work lock unlock keyless, cause above topclef write can't done.
    newone's Avatar
    Oct 2016
    i wtote about the proccedure,i think tha tey are reusamble but first write page 10 and 11 0000 so anything goes wrong you can try again
  8. #6
    topclef's Avatar
    first , what device you'll use to this Job ?
  9. #7
    Jun 2014
    Quote Originally Posted by topclef View Post
    i use vvdi2.
  10. #8
    Jun 2014
    hi, did any one have an idea what I must to do to work the keyless go of the remote? I adapt the remote key the car now start urgent when I put the key near the immo coil, is any one have solution please for keylessgo? thank you in advance...
  11. #9
    Jan 2016
    Quote Originally Posted by pouleddy View Post
    You must have proper Keyless key and do key learn procedure. Not add to immo directly. VVDI2 does keyless good. Xhorse team enabled this option for Golf VI earlier than Abrites...
    Wysłane z mojego SM-G950F przy użyciu Tapatalka
  12. The Following User Says Thank You to amigokola For This Useful Post:
    pouleddy (29th January, 2018)
  13. #10
    Jun 2014
    Quote Originally Posted by amigokola View Post
    Hi, thank you for your answer, but I do same as you write to me, and I follow well the procedure of vvdi2 it so easy,but when finish the programming,& the car just start when I put the remote near the immo coil. if the remote far then immo coil then after don't work by the start/stop button, the remote used not new but for keyless system, and the transponder inside it new. so any info I hope some one have solution?
  14. #11
    Jan 2016
    Wrong key ??
  15. The Following User Says Thank You to amigokola For This Useful Post:
  16. #12
    Jun 2014
    Wrong key ??
    no dear not wrong key its same as original part number and the pcb with keyless. any new info please?
  17. #13
    z786's Avatar
    10 Steps Ahead of You
    Have you tried new batteries
    "I always tell the truth. Even when I lie"
    "We Taking Over, One City At A Time"
  18. The Following User Says Thank You to z786 For This Useful Post:
  19. #14
    Jun 2014
    Quote Originally Posted by z786 View Post
    yes I also try put a new remote battery and can't work.
  20. #15
    You can't reuse keyless keys like normal remotes. The transponder and keyless part is integrated so changing the chip gives it a new ID
    Sent from my SM-G930W8 using Tapatalk
  21. The Following User Says Thank You to dmp For This Useful Post:
