FIAT BRAVO, HELP U1726
Results 1 to 7 of 7
    Spain
    Default FIAT BRAVO, HELP U1726
    Hello friends, I have a problem with this airbag ecu.
    Fiat Bravo
    5wk43641
    51827585
    Do not crash data. Error code U1726.
    Any solution?
    Many thanks in advance..
    If I helped, please, use buttons reputation + thanks.
    Many thanks
    MARIENBURG
    could you write down what that mean U1726?
    Top Poster ercbarbosa's Avatar
    Jan 2018
    Hello Friend! I have the crash / clear file for this module. You can do the comparison and see if you can find something. I hope to help, good work!
    Spain
    Quote Originally Posted by ercbarbosa View Post
    Please send pasword
    Many thanks
    Spain
    his file is not the same as my.
    The two references do not match, and there are variations in the programming.
    Thank you anyway.
    Many thanks
    Spain
    any other suggestions?.
    Many thanks
    Jan 2018
    Try this! Compare your file and the blocks are very similar!
    Good luck!
  8. The Following User Says Thank You to ercbarbosa For This Useful Post:
    ernesto1670 (22nd January, 2018)
