help to sync dash and ecu 0281011216 ecd16c34 , dash 9s12h256. Thanx
Hello, if PATS is timed use VCM/IDS diagnostic
2006 model ? is timed system.
first you programm 2 keys, after execute module initializing....all process it takes 22 minutes.
is not time ..is with incode ....but i reflash ecu with vcm ...but same p1259-62
vcm is not working on this car ....
i do one with ford all in one ...some time ago but my pc hdd fail and i lost all data ...
try it..........
Mr BLACK (22nd January, 2018)
try to reload file ...i can not open archive. thanx
WinRAR ZIP archive pass in pm.
archive is ok ..thanx i post result
car started.....thanx ....but i do not understand from where is data from eeprom ....in dash eeprom i can not see data ....
I have same error but when try to resync with VCM, after I put good incode sw returns me to previous screen, not shows what to reset PCM or PIP etc...
Tried to erase keys and reprogram but still same
Any help or to read ecu <> dfash manually for sunc?
Tnx
Reality of life :
1:Never argue with an idiot, he will pull you down to his level and overcome you with experience
2:Envy is the confession of inferiority
3:Everyone lies
How much trash you leave behind so much trash someone will have to read or maybe you yourself
If you like reading garbage, don't slow down, just speed it up
Here is
Tnx
dash readed with smok obd
