write, pass pm
Hello guys,
I did DPF off on this file 2 years ago and it was all good.
Customer comes now says DPF lamp is on and car in safe mode.
I scan the car and this 2 DTC's show:
P0030 O2 Heater Control Circuit Bank 1 Sensor 1
P0133 O2 Sensor Circuit Bank 1 Sensor 1
Can anyone do Lambda off on this file please?
Regards,
Sima
write, pass pm
FILE SERVICE
this should work if you want to try
simaservis1108 (24th January, 2018)
no need unplug
FILE SERVICE
Hm... if this was my customer... I would have told him - "Go ~~~~ yourself!"
Actually this sensor is not DPF related.
And if he don't want to service such car, with many "electronic things"... tell him to drive a car with Perkins engine...
NO PASSWORDS FOR ANYONE, EXCEPT THE RECIPIENT OF THE FILE !!!
If your PM box is full, clean it right now...
Otherwise, your requested file will be deleted... for ever!
pike (23rd January, 2018), simaservis1108 (24th January, 2018)
Yes,but explain that to him.
Official service told him it is DPF related.
posible delete p0133 o2 sensor slow response & safe mode for this dtc ? mazda 6 diesel
I have the same problem. DTC P0133 and limp mode. This problem comes now, after some time of DPF off. Can be DPF off releated problem or just simple lamba sonda is bad? I think this beacuse in this car sonda placed after DPF and it is maybe sooty because DPF drilled.
Possible to switch off lambda in this ECU?
DTC P0133
No one can help?
Fec001 (17th October, 2018)
If Possible,need lambda off too (P0133).
sepistar (17th February, 2019)
hi could u help me with mazda 6 2.2 r2aa denso ecu need lambda off cus getting codes P0030:00EF and P0030 got dpf off just need lambda off
txirri (19th April, 2021)
