Results 1 to 15 of 15
    simaservis1108's Avatar
    Aug 2013
    Serbia,Belgrade
    Default Mazda 6 Denso Lambda off
    Hello guys,
    I did DPF off on this file 2 years ago and it was all good.
    Customer comes now says DPF lamp is on and car in safe mode.
    I scan the car and this 2 DTC's show:
    P0030 O2 Heater Control Circuit Bank 1 Sensor 1
    P0133 O2 Sensor Circuit Bank 1 Sensor 1
    Can anyone do Lambda off on this file please?
    Regards,
    Sima
    Sep 2016
    Poland
    write, pass pm
    FILE SERVICE
    Aug 2013
    Serbia,Belgrade
    Quote Originally Posted by voltechcar View Post
    write, pass pm
    Lambda need unplug or?
    johak's Avatar
    Apr 2010
    this should work if you want to try
  5. The Following User Says Thank You to johak For This Useful Post:
    simaservis1108 (24th January, 2018)
  6. #5
    Sep 2016
    Poland
    no need unplug
    FILE SERVICE
  7. The Following User Says Thank You to voltechcar For This Useful Post:
  8. #6
    bobolin4o's Avatar
    Apr 2010
    Bulgaria, V. Tarnovo
    Quote Originally Posted by simaservis1108 View Post
    Hello guys,
    Regards,
    Sima
    Hm... if this was my customer... I would have told him - "Go ~~~~ yourself!"
    Actually this sensor is not DPF related.
    And if he don't want to service such car, with many "electronic things"... tell him to drive a car with Perkins engine...
    NO PASSWORDS FOR ANYONE, EXCEPT THE RECIPIENT OF THE FILE !!!
    If your PM box is full, clean it right now...
    Otherwise, your requested file will be deleted... for ever!
  9. The Following 2 Users Say Thank You to bobolin4o For This Useful Post:
    pike (23rd January, 2018), simaservis1108 (24th January, 2018)
  10. #7
    Aug 2013
    Serbia,Belgrade
    Yes,but explain that to him.
    Official service told him it is DPF related.
  11. #8
    posible delete p0133 o2 sensor slow response & safe mode for this dtc ? mazda 6 diesel
  12. #9
    Fec001's Avatar
    Apr 2010
    I have the same problem. DTC P0133 and limp mode. This problem comes now, after some time of DPF off. Can be DPF off releated problem or just simple lamba sonda is bad? I think this beacuse in this car sonda placed after DPF and it is maybe sooty because DPF drilled.
    Possible to switch off lambda in this ECU?
    DTC P0133
  13. #10
    Fec001's Avatar
    Apr 2010
    No one can help?
  14. #11
    johak's Avatar
    Apr 2010
    here you go
  15. The Following User Says Thank You to johak For This Useful Post:
    Fec001 (17th October, 2018)
  16. #12
    Jul 2010
    If Possible,need lambda off too (P0133).
  17. #13
    mprog's Avatar
    Feb 2017
    Europe
    Quote Originally Posted by sepistar View Post
    Your file
    Pass in PM
    Best Regards
  18. The Following User Says Thank You to mprog For This Useful Post:
    sepistar (17th February, 2019)
  19. #14
    Jul 2010
    Quote Originally Posted by mprog View Post
    Your file
    Pass in PM
    Best Regards
    Today have time to check the file
    No more P0133,
    But now P0563?
    So make sense to disable P0563 too?
    Battery and charger are ok.
  20. #15
    May 2017
    trowbridge uk
    Default help
    hi could u help me with mazda 6 2.2 r2aa denso ecu need lambda off cus getting codes P0030:00EF and P0030 got dpf off just need lambda off
  21. The Following User Says Thank You to Slav1984 For This Useful Post:
    txirri (19th April, 2021)
