Results 1 to 10 of 10
    Nov 2016
    Default Mercedes EIS MOdule reset
    HEllo
    I have a dead MCU MC68HC705
    with mask 1D69J .
    Can anyone tell me where can i buy a MCU ?
    or any website please ?
    Did you have tool to write ROM in new mcu ?
    Nov 2016
    Yes i have Digimaster 3
    i need a blank MCU or New MCU
    droidwayne65's Avatar
    Aug 2015
    North America
    Quote Originally Posted by Shakeelbhugeloo View Post
    What do you plan to do with the new mcu?
    Nov 2016
    Replace the damaged one.
    and i using same data on the first to the new one.
    Aug 2015
    North America
    Ahhhh, so the original still communicates or failed after it was dumped? May be easier to pick up a used EIS and clone both mcus or use use just one from it, if you're sure nothing else is wrong with the original EIS.
    Apr 2016
    holland
    check soldering connections ore do it one more time this mcu dont get broken fast most time connection problem
    Aug 2013
    The only way to make this work is you need to get another EIS with the same mask, and write the original EEPROM into the outside MCU and inside MCU.
    Nothing that I'm aware of can read and write ROM. Outside MCU ROM is different than inside MCU ROM.
  9. The Following User Says Thank You to duplikeytor For This Useful Post:
    Shakeelbhugeloo (25th January, 2018)
  10. #9
    Nov 2016
    Thanks man understood
  11. #10
    bram380's Avatar
    Indonesia +628153111774
    HEllo
    with mask 1D69J .
    http://www.digital-kaos.co.uk/forums...S-210-545-0308
  12. The Following User Says Thank You to bram380 For This Useful Post:
