Page 2 of 2 FirstFirst 12
Results 16 to 17 of 17
  1. #16
    Quote Originally Posted by runtronics974 View Post
    Hello
    maybe you have to check wiring from diag plug to your BSI
    have you access others systems on the car ?
    best regards
    Hi the connections are ok.....
    It seems to be that the bsi entered in boot mode, how can resolve this issue?
  2. #17
    May 2018
    Quote Originally Posted by micdesa View Post
    Sorry if this seems like a dumb question...
    Are you running Global test, and does it still have dialogue with all the other ECUs?
    Just checking whether there hasn't been a random/coincidental failure of the hardware (either the diagnostic socket or the interface)?
    I appreciate that you say you have checked the wiring from the diag plug to the BSI but just double checking there is still some actual data coming out and being read correctly!
    Duh just realised this is along the same lines as runtronics974 but I am not sure if by "connections" you meant the wiring or the data!!
    Hello
    .....have you access others systems on the car
