Results 1 to 15 of 17
    Default BSI NO DIALOG - Citroen C5 X7
    Hi Guys,
    Sorry for my bad English
    I modified some settings on my citroen c5 using Lexia 345. In order to apply the changes it asks me for code and I insert 03114.
    The operation completed successfully.
    After that I can't able to read bsi info anymore.
    Lexia and Diagbox show me "BSI no dialog" error. I tried to reset the BSI but there are no changes.
    The messdage is the same "BSI no dialog". Now I to change some settings becasue my lights and my arrows doesn't work anymore.
    I'm desperate. I tried different version of lecia and diagbox but the prbolem still there.
    Please help me!!!! I'm desperate.
    Hi Guys,
    I've virginized my BSI.
    Now I'm looking for tutorial in order to reprogram it with diagbox.
    CAN ANYONE HELP ME?
    Junior Member MJeppesen24's Avatar
    Jan 2018
    Denmark
    Quote Originally Posted by micdesa View Post
    Hi Guys,
    CAN ANYONE HELP ME?
    Always take a print of parameter in the bsi before changing the coding.
    If you have access to the diagbox .. then make a print of parameter in the bsi before you make virgin bsi. then you have the option to code the bsi for your car correctly.
  4. The Following User Says Thank You to MJeppesen24 For This Useful Post:
    micdesa (25th January, 2018)
    Quote Originally Posted by MJeppesen24 View Post
    I have all info...moreover i have bsi dump. What i need is the key code....could you help me?
    Inviato dal mio D6503 utilizzando Tapatalk
    Jan 2018
    Denmark
    add dump file and I will try
    Here you are.....Hope you can help me....
    thanks in advance.
    Jan 2018
    Denmark
    thanks in advance.
    key code should be one of them
    HHDD
    HDDD
    DDDD
    thanks in advance
  9. The Following User Says Thank You to MJeppesen24 For This Useful Post:
  10. #8
    Thanks.....Hope that works....
    Just another questions....where I can find the virignized file for this bsi?
  11. #9
    Jan 2018
    Denmark
    hope it works for you ...
    thanks in return
  12. The Following User Says Thank You to MJeppesen24 For This Useful Post:
  13. #10
    thanks in return
    Thanks you are my hero
  14. #11
    Jan 2018
    Denmark
    did you get the job done?
  15. #12
    It doesn t work
  16. The Following User Says Thank You to micdesa For This Useful Post:
    issam216 (31st January, 2018)
  17. #13
    Feb 2017
    Tunisia
    TRY TO CODE KEY WITH THE FOLLOWING CODE
    PIN : DVSK OR KSVD
  18. #14
    Hi Guys,
    I'm here again.....I tried all.....even if change the bsi.
    My initial issue is the same...My Lexia tells me there is no dialogue wuth BSI.
    What Can I verify too.
    Someone could verify if my bsi dump is correct?
    Help me please.
  19. #15
    Jul 2016
    Reunion Island
    Hi Guys,
    Help me please.
    Hello
    maybe you have to check wiring from diag plug to your BSI
    have you access others systems on the car ?
    best regards
