Results 1 to 5 of 5
    Jul 2016
    anywere
    Default vw steering assistance fault vento code P160900
    hi i change air bags and seat belts and module to but in the dash appear ligth steering weel red and the steering column is hard
    some one have idea from this case
    code fault p160900
    Oct 2012
    London
    Not sure of system on the Vento but most electric power steering receive message from SRS to deactivate due to high current/heat. Is this a new SRS module or cleared crash? also have you checked coding correct for power steering module installed?
    Aug 2016
    first, remove all errors in the SRS block and then remove errors in the 44 block
    sergei5005's Avatar
    Nov 2012
    Bs As
    Excuseme sir..What is 44 block ??? THANKKK KSSSSSS !!!
    Quote Originally Posted by ra4yel View Post
    Dunker's Avatar
    Yorkshire
    I would have thought 44 is steering assist.
    http://wiki.ross-tech.com/wiki/index...7/P1609/005641
    V Series TMS470 / EEPROM data - encryption / decryption, totally pwned.
    IEC 62056-21 - new discussion: sonsivri.to/forum/index.php?topic=60412.0
  6. The Following User Says Thank You to Dunker For This Useful Post:
    sergei5005 (25th April, 2018)
