Page 3 of 8 FirstFirst 12345678 LastLast
Results 31 to 45 of 115
  1. #31
    dd1's Avatar
    Aug 2014
    So basically this is what I am looking for? My key is from the dealer, do I still need to work on the eep?
  2. #32
    kiszka's Avatar
    Reality of life :
    1:Never argue with an idiot, he will pull you down to his level and overcome you with experience
    2:Envy is the confession of inferiority
    3:Everyone lies
    How much trash you leave behind so much trash someone will have to read or maybe you yourself
    If you like reading garbage, don't slow down, just speed it up
  3. #33
    dd1's Avatar
    Aug 2014
    This is what I am getting. Incl photo
  4. #34
    dd1's Avatar
    Aug 2014
    Engine start and transponder learnt never turns YES.
  5. #35
    kiszka's Avatar
    Reality of life :
    3:Everyone lies
  6. #36
    dd1's Avatar
    Aug 2014
    you mean repeat the key programming process?
  7. #37
    kiszka's Avatar
    Quote Originally Posted by dd1 View Post
    yes yes....
    Reality of life :
    3:Everyone lies
  8. #38
    dd1's Avatar
    Aug 2014
    It is not changing. Won't program.
  9. #39
    Faraday's Avatar
    May 2012
    The dark side of the moon
    From your picture I can see 2 problems Engine start permited NO and wait time 10 min
  10. #40
    Jan 2016
    VW Passat CC USA has immo in CCM not in dash. Did one CC USA lately...
    Quote Originally Posted by rob h View Post
    Europe in ccm, usa in cluster, Correct Faraday, good thing, pointing this out.
  11. #41
    dd1's Avatar
    Aug 2014
    What should I do to get this car running ?
  12. #42
    dd1's Avatar
    Aug 2014
    Do we give up on this car?????
  13. #43
    Jun 2013
    Always smart to read eeprom on these. Then you can write back the original, when you have small accidents with the OBD tools.
    I think the dealer can help you out fast, in this case now.
    You can always try with a force OBD ignition tool. If the car is far away from the dealer. But the you need several day, to get that tool delivered as well.
    This should have taken maybe 60 minutes in total with eeprom. (Plus plastic key cutting) If you knew where it was located, when you started with this vehicle.
    But then you should just used a clean key from any seller.
    And you have the tool to make it. With Immo Data tool. Just need to have something to read the eeprom.
    If you read the dump and save. And then maybe try to add a new clean key, by dump. And save that as well, and try to write back.
    Make a test if starting or not. I guess not.
    And post both dumps.
    There are people in here, which are able to edit the dump to make it start. I am not one of them.
    Delete DTC's and do the waiting time which it says is necessary.
    Or maybe you can call some colleague which have some extra tools, and more experience. To help you out.
  14. The Following User Says Thank You to Weasel3 For This Useful Post:
    dd1 (6th February, 2018)
  15. #44
    dd1's Avatar
    Aug 2014
    The car came from the dealer.....key is new from the dealer. The couldn't prog it. I can force obd2 and get the pin code already. But as you can see wont prog it. You suggest get a blank key and work on that?
  16. #45
    Oct 2014
    Netherlands
    How to program new key to Passat with immo in CCM:
    - Read 95320 eeprom from CCM module (behind glove box)
    - Extract CS data from it
    - Extract PIN code from it
    - Prepare ID48 as TP23. Write CS data to transponder (make it a dealer key)
    (If you have a dealer key then you don't need to do this, but if your dealer key cannot be learned then make a dealer key yourself as I just explained.)
    - Learn this transponder using VCDS Adaptation channels when going to CCM module (25)
    http://wiki.ross-tech.com/wiki/index...r_Key_Matching
  17. The Following 2 Users Say Thank You to H2Deetoo For This Useful Post:
    amigokola (7th February, 2018), dd1 (7th February, 2018)
