In your case you should extract pin code (no need CS since you have dealer key) and do adaption for keys.
dd1 (31st January, 2018)
Hi. Pin code from Ecu or kessy? This is kessy right? Thnx
Hello.
your car was comfort module not kessy. and you must read from engine ecu by vvdi2, can't you read by obd2 comfort module pin, must dismount to read eeprom to have immo pin, just, i load to you a photo to see how you begin to read ecu and from same place you can adapt your dealer key.
So I have to read comfort and Ecu eep or one of them?
Thnx. But remember mine is the 1st version of vvdi, not vvdi2. But it has this option I have check it again
It is this type of key.
hi everyone, my vvdi was not able to read the pin by obd2. now, to read it off of the eep, do i need to pull out the ecm and comfort access or just any of them will have the pin? thnx in advance
Hi. Is it eep? If so which one is it? Do you have photo of the eep location in the comfort and Ecu ? Thnx in advance
If to read obd2 the Ecu. Do I have to power the system on? I don't have working key
HI everyone, can anyone tell me which eep contains the pin code for the key programming? dealer key for the MED17.5
pin in ccm module, located behind glove box, eeprom 95320, vvdi will be able to get pin out of this eeprom.
pics attached.
dd1 (3rd February, 2018)
Thnx but mine is abrites. I have tried by obd2 no luck. Some suggest to work on MED17.5 if I read the eep and list it here, can you guys get the pin code out of it?
