Becker BE6431 upgrade softwere
Results 1 to 8 of 8
    Serbia
    Default Becker BE6431 upgrade softwere
    Head Unit NG4 Becker BE6431 software installation is required.
    When the system is switched on, the system starts and after a few seconds the system restarts and reboots, and thus to infinity.
    I need the instruction and software for upgrading the device itself. The device has HDD as shown in the pictures!
    simaservis1108's Avatar
    Aug 2013
    Serbia,Belgrade
    Not a software problem only.
    Sima
    It's not easy but it's possible
    the layout is shown in the images
    All modules are solder and do not try to remove themCPU board.jpgCPU Board Bottom.jpgPower Supply.jpgRemove metal.jpgus a soldering flux and Rework soldering station
    Fix reatarting and rebootingNG4 Restarting.jpg All BGA device and memory hawe silicon termal conductiv rubber onli 1 hawe difrent blue for high temperature.
    dis device making the problem rebooting and restarting.
    Im fix the problem rebooting now all working for 10
    Aug 2013
    Serbia,Belgrade
    Definitely don't do that.
    You don't know what you are doing.
    And in desperate attempt to do something,you just make shit on the board...
    I know very well what I'm doing and how this device works
    and you are trying to make primitive things yourself as an experiment that is very stupid
    and you too are immature and in fact you are not the opposite.
    Drugim riječima SIMA ne sri matereti
    Aug 2013
    Serbia,Belgrade
    If you know very well,then why rework whole board?Why rework that board anyway?Only because it has BGA elements???
    Lets go ahead and drop the vertical board in flux and heat everything???
    That shows you don't even have a clue how this device works...
