SOw how can we put this firmware in VAG405 unit?
I have it with v2.8 but it stoped showing DTC definitions!?
Any Ideas why?
will the 2.7 sofware let me reset seat ibiza 2008/9 service indicator
I have same problem with VAG405.Its work but when i get DTC i don t have definition,any ideea how to upgrade the firmware?
Anyone ever had the vag405 just show the backlit screen? Any sign of the downloader to install updates for the 405? No updates on the Autel websites, is this unit now obsolete?
Does anyone know if you can put this firmware on a MaxScan GS500?
Any firmware newer than 2.7 ?
thank merci
thank you very much
hi im a newbie i have a vag405 running v2.2 and was wondering if anyone has found v2.8 available yet??
regards
barry
i have version 2.8 but it doesnt work on my b5 turbo a4. will the 2.7 work????
Can somebody please post the 2.7 or 2.8 english firmware por vag405 ? thanks
Just some more words about this obsolete scanner ...it can be "updated" , you must solder 4 wire from a USB cable to some pins on the board ,there is a FT232BL..I ve managed to update /rebrand it but the DTC definitions still don t work .The reason is the lack of AT45DB081B flash memory I guess .there is a file called AT45DB081B.bin in the update file but no AT45DB081B on the board or similar
Yeah I had one the eibd version made it into the vag one, then robbed a trsnsister out of it!
very easy to make the USB lead. Datasheet fir 232 chip, then meter to docket 16 pin plug from maplin onto a regular USB cord
