Hello, the version 2.7 is still the latest official version available?
Thanks !!!! hope DTC will be updated
Thanks guys!
Thank You very much for that 2.7 firmware. I've found only one flash-chip on that scanner board - it's Atmel's 45DB041D :-)
Someone found 2.8 yet?
hi guys, got a vag 405 for my audi and it doesnt read the codes.... hopefully i can get it fixed.
thanks for alll
I just have registered. I am looking to download firmware 2.7 which appears to be available on top of the thread. However, I am new user so I probably wait for 15mins to download. I have a question to ask. My VAG405 does not start when I connect it to computer. It works with Audi (partially may be due to lower firmware version). So even I get firmware downloaded, I am not sure how to install as my computer does not recognize the device. Any idea is greatly appreciated. Thanks you.
I also have this doubt
Hi Newbie,
I was wondering if your v2.7 firmware worked better than the v2.2 ? I experience the same problems...
2.7 , 2.2 same s*it , buy vcds ,cheaper and better .For those who can t connect using USB you must open and check for FT232 .
Last 10 posters have max 2 posts ,how interesting
Thank You very much,firmware V2.2 updated successfully to V2.7 and now works fine,corrected the problem of the "keyboard's over-sensitiveness".!!!
Does this work on a Golf MK7? Thanks
hi im looking for the 2.7 upgrade and want to know if there are drivers available for win 7 as my pc is not detecting the vag405 at all vag is v2.7 but not listing dtc,s tks
