Page 1 of 4 1234 LastLast
Results 1 to 15 of 53
    Oct 2008
    heaven
    Default Autel VAG405 MaxiScan Firmware
    hello
    i looking last firmware update v2.7 for vag405.. now 2.2 i want update to 2.7 version who can help
    Oct 2008
    need it into German. here in English it has someone into German
    RapidShare Webhosting + Webspace
    Sorry for my English
    I have been informed that v2.8 is out but Autel have not answered any e-mails.
    Could / would anyone like to share
    Many thanks
    here's 2.7
  5. The Following 5 Users Say Thank You to party7uk For This Useful Post:
    Axel5192 (5th January, 2019), dexter18 (19th December, 2018), duckstar (7th October, 2020), JuzzyQLD (22nd July, 2018), przemeck (10th February, 2016)
    Oct 2008
    Quote Originally Posted by party7uk View Post
    here's 2.7
    whats the language english ???? i need to german language
    pls can you help me
    Oct 2008
    heaven
    who have v2.8 firmware
    Oct 2008
    who has a German version of vag405
    does anyone have 2.8 firmware for the autel vag405
  10. #9
    Member Tommy123Tommy's Avatar
    it is not diffrent from 2.7 and 2.7 is no diffrent from the 2.6
    2.6 is the last update sent to sealey and the 2.7 2.8 are just an edited file to make it say that, it is just a trick for one seller to have later verion than other with no real change
  11. #10
    i just got the vag405 and it worked well. after i tryed to hook it up to my laptop i used it on my car and now it says link error i tryed evrything and nothing works, when i hookit up tomy laptop nothing happens my laptop recognizes it but thats about it nothing turns on on the scrren of the scanner. i went everywhere lookin for driver downloads updates, my current firmware is 2.8v, i dont kno what else to do, can someone help thanx
  12. #11
    did you press the button, think its the down one , other than that , uninstall the drivers and reinstall them, why are you connecting it too the pc if you have the so callled latest version .
    another note to add, is to adjust the contrast after update because if you do not it is harder after because contrast goes to 8% ish
  13. #12
    Shenzhen
    V2.7 is the latest official version of Autel VAG405. Comparing with V2.6, it has added some DTC definitions to the tool and corrected the problem of the keyboard's over-sensitiveness. If you want the update software, please visit ( link and addy removed )
    Last edited by gmb45; 21st December, 2010 at 07:41 AM. Reason: link and addy removed
  14. #13
    Default how s work? tks
    here's 2.7
    hows worl this firmware? how can I put it on?
  15. #14
    here's 2.7
    I'll have a look at what is actually in this file. I don'y have one of these scanners yet but am contemplating buying one, especially if the firmware shows signs of being hackable - as in make it do more than the original hardware was meant to do. Ideally it would do what VCDS does without needing to lug along a laptop and kowtow to RossTech by buying one of their scandalously overpriced cables. They reversed the original VAS scanner so I don't see why that can't be done again. It is not as if this needs a beefy CPU - just push some bits over a serial or CAN bus line and that's it...
  16. #15
    Default newbie with v2.2 on my VAG 405
    Hi all, Just registered for the forum today. I tried using my VAG 405 today to set my Passat into Longlife service mode (I have checked and my ECU does support it) however the firmware didn't seem to recognize the car. Hoping v2.7 might be better.
