Automat (16th March, 2019)
Looks like new software on a new unit will be more as well.
http://locksmithsupplystore.com/IKEY...TWAER_p_1.html
2012 Cruze did not power on with obd , with both Ikey-820 and IFIX919
Hi DK,i test on f150 2018 all key lost and add key no success pincode error so i test on rav4 2016 immo reset and program key ok,thanks.
2016 ford mustang prox 900Mhz remote start AKL USA ACTIVE ALARM
plug into port place key in slot under cup holder and start to program and wait 10 min for alarm to chirp twice THEN AFTER CHIRPS hit program keys
says wait ten minutes and goes maybe 5 minutes and key is programmed SUCCESS
Automat (16th March, 2019), darknezz19 (27th November, 2018), HeXeN (7th November, 2018), p1et (29th November, 2018)
2018 cruze key and remot not working
Hi DK,i test on Ford f150 2009 for add key after aprox 10 seconds success,i think than bypass 10 minutes wait for access granted,thanks.
Range Rover 2006 Added spare key in seconds. KVM dealer update does not affect this year and only have to worry about that for 2010'ish and newer is that correct?
2002 acura TL USA AKL
ikey820 does not have this year listed trying 2001 and 2003 get you nothing but an error FAIL
i tried x300DP next and it also fails as it does not go below 05 or 06 and all attempts to program and to run auto scan fail FAIL
next up is the SKP900 fail to connect FAIL
last up is the oldie but goodie drumroll please ck200 programs in key in about 30 secs after the usual on off on off business under i believe a canadian ML?(top one in acura)
now there is no particular one for this car model and year
it does not exist on the ck200 and all other tries at using the other models and years failed to connect at all most times"ecu not found"
but apparently its got the right sauce inside somewhere so
SUCCESS
2012 cadillac escalade USA AKL
first up ikey 820 FAIL does not have 2012 as an available year and again choosing anything else gets you an error no matter what you choose
next up X300DP FAIL it starts the 12 minute count and at the end the keys do not program in
and of course to save the day we have the CK200 the little badass that it is
and of course it does not have a listing for a 2012 cadillac escalade
only has 07-11 and that does not communicate(ecu not found)
HOWEVER going over to chevrolet silverado gets you comms and a 12 minute count down after which the keys programmed in without hesitation SUCCESS
Automat (16th March, 2019), darknezz19 (29th November, 2018)
ok so im thinking the error i keep getting is a database error as i got it today on a 07 impala and again had to pull out the old ck200
so i updated today and ill see what happens
btw still
HW: 3.1
SW: 2.1.4
UI: 1.2.4
I am interested in the IKEY820 programmer.
Are tokens needed to use this programmer or are they unlimited tokens?
What is the latest version of the software?
Do you have a change log with the list of vehicles added as you update?
I am in Canada, where can I buy the IKEY820?
Best regard
I'm in the same boat as you kitten13, I'm thinking of purchasing this unit too (autek ikey820) ..... I found a couple places online that are selling it for $550 ...... by the time it gets to canada, I'm guessing $800 with exchange and shipping, which is still not too bad.
Craig
All the info is in the thread, do the leg work.
2010 silverado akl, failed to comunicate when adding key or programming remote. Ck200 saved the day.
I try today with 2016 Altima usa , its did not red the pin code so i ended remove the cluster and red the pcm number and type the last fife number with xtool pro its give me the new and old pin . put its did not program the key its say pcm error in both of them
