Page 6 of 15 FirstFirst 1234567891011 ... LastLast
Results 76 to 90 of 218
  1. #76
    Mar 2010
    Looks like they are now charging for upgrades, it will cost $200 to add this option. Does this mean the base unit will increase by $200 or will the new units include it for free?
  2. The Following User Says Thank You to keysmith For This Useful Post:
    Automat (16th March, 2019)
  3. #77
    Jun 2017
    US
    Looks like new software on a new unit will be more as well.
    http://locksmithsupplystore.com/IKEY...TWAER_p_1.html
  4. The Following User Says Thank You to darknezz19 For This Useful Post:
  5. #78
    Aug 2018
    USA
    2012 Cruze did not power on with obd , with both Ikey-820 and IFIX919
  6. #79
    Mar 2010
    Canada
    Hi DK,i test on f150 2018 all key lost and add key no success pincode error so i test on rav4 2016 immo reset and program key ok,thanks.
  7. The Following User Says Thank You to starmobile For This Useful Post:
  8. #80
    Jan 2017
    USA ����
    2016 ford mustang prox 900Mhz remote start AKL USA ACTIVE ALARM
    plug into port place key in slot under cup holder and start to program and wait 10 min for alarm to chirp twice THEN AFTER CHIRPS hit program keys
    says wait ten minutes and goes maybe 5 minutes and key is programmed SUCCESS
    The thanks button is HERE looks like this --->>> THANKS
  9. The Following 4 Users Say Thank You to sleepyrz For This Useful Post:
    Automat (16th March, 2019), darknezz19 (27th November, 2018), HeXeN (7th November, 2018), p1et (29th November, 2018)
  10. #81
    Aug 2018
    USA
    2018 cruze key and remot not working
  11. The Following User Says Thank You to hai82der For This Useful Post:
  12. #82
    Mar 2010
    Canada
    Hi DK,i test on Ford f150 2009 for add key after aprox 10 seconds success,i think than bypass 10 minutes wait for access granted,thanks.
  13. The Following User Says Thank You to starmobile For This Useful Post:
  14. #83
    Jun 2017
    US
    Range Rover 2006 Added spare key in seconds. KVM dealer update does not affect this year and only have to worry about that for 2010'ish and newer is that correct?
  15. #84
    Jan 2017
    USA ����
    2002 acura TL USA AKL
    ikey820 does not have this year listed trying 2001 and 2003 get you nothing but an error FAIL
    i tried x300DP next and it also fails as it does not go below 05 or 06 and all attempts to program and to run auto scan fail FAIL
    next up is the SKP900 fail to connect FAIL
    last up is the oldie but goodie drumroll please ck200 programs in key in about 30 secs after the usual on off on off business under i believe a canadian ML?(top one in acura)
    now there is no particular one for this car model and year
    it does not exist on the ck200 and all other tries at using the other models and years failed to connect at all most times"ecu not found"
    but apparently its got the right sauce inside somewhere so
    SUCCESS
  16. The Following User Says Thank You to sleepyrz For This Useful Post:
  17. #85
    Jan 2017
    USA ����
    2012 cadillac escalade USA AKL
    first up ikey 820 FAIL does not have 2012 as an available year and again choosing anything else gets you an error no matter what you choose
    next up X300DP FAIL it starts the 12 minute count and at the end the keys do not program in
    and of course to save the day we have the CK200 the little badass that it is
    and of course it does not have a listing for a 2012 cadillac escalade
    only has 07-11 and that does not communicate(ecu not found)
    HOWEVER going over to chevrolet silverado gets you comms and a 12 minute count down after which the keys programmed in without hesitation SUCCESS
  18. The Following 2 Users Say Thank You to sleepyrz For This Useful Post:
    Automat (16th March, 2019), darknezz19 (29th November, 2018)
  19. #86
    Jan 2017
    USA ����
    ok so im thinking the error i keep getting is a database error as i got it today on a 07 impala and again had to pull out the old ck200
    so i updated today and ill see what happens
    btw still
    HW: 3.1
    SW: 2.1.4
    UI: 1.2.4
  20. The Following User Says Thank You to sleepyrz For This Useful Post:
  21. #87
    kitten13's Avatar
    Feb 2010
    Hello,
    I am interested in the IKEY820 programmer.
    Are tokens needed to use this programmer or are they unlimited tokens?
    What is the latest version of the software?
    Do you have a change log with the list of vehicles added as you update?
    I am in Canada, where can I buy the IKEY820?
    Best regard
  22. #88
    Dec 2018
    Ontario, Canada
    I'm in the same boat as you kitten13, I'm thinking of purchasing this unit too (autek ikey820) ..... I found a couple places online that are selling it for $550 ...... by the time it gets to canada, I'm guessing $800 with exchange and shipping, which is still not too bad.
    Craig
  23. #89
    Jun 2017
    US
    All the info is in the thread, do the leg work.
    2010 silverado akl, failed to comunicate when adding key or programming remote. Ck200 saved the day.
  24. The Following User Says Thank You to darknezz19 For This Useful Post:
  25. #90
    Aug 2018
    USA
    I try today with 2016 Altima usa , its did not red the pin code so i ended remove the cluster and red the pcm number and type the last fife number with xtool pro its give me the new and old pin . put its did not program the key its say pcm error in both of them
  26. The Following User Says Thank You to hai82der For This Useful Post:
