Inspect under wipers if no water. There are some connections in fusebox, maybe corosive
Hi, I have problem with abs/esp on this car.
Module is 8E0 614 517
Care came to me with fault 01200 ABS Valves Voltage Suply, I have checked all of fuses and terminals on connector for battery voltage and ground and ignition voltage, everything is fine.
Car has been in garage at night, but in morning no communication with abs.
I checked with another module of the same number, coded it, seems ok, but after two ignition on and off, no communication with abs. Old module wont communicate at all.
If someone knows anything about this pls help.
Thanks a lot
Has this one got them silly strip fuses on the battery? If it has give them a poke.
V Series TMS470 / EEPROM data - encryption / decryption, totally pwned.
IEC 62056-21 - new discussion: sonsivri.to/forum/index.php?topic=60412.0
