CG PRO PROGRAMMER 9S12
Page 1 of 2 12 LastLast
Results 1 to 15 of 20
    Apr 2010
    Default CG PRO 9S12 PROGRAMMER
    NEW CGDI FACTORY TOOL,
    I would like to know if it will make FRM decript BMW and fix 9S12 9S12XEQ384 corrupt.
    It will be better than your competitors XPROG and VVDI PROG.
    lion0304's Avatar
    Oct 2014
    Disable your caplock.
    jakesman's Avatar
    Oct 2013
    Bethlehem Southafrica
    Quote Originally Posted by giovani View Post
    I WOULD LIKE TO KNOW IF IT WILL MAKE FRM DECRIPT BMW AND FIX 9S12 9S12XEQ384 CORRUPT.
    IT WILL BE BETTER THAN YOUR COMPETITORS XPROG AND VVDI PROG
    same here , I have been looking at it but at around $ 350 for it , it have some Benz functions and mostly BMW functions and a bit of other stuff I might be a nice add on to existing tools , but will it do what they say it can do , because I also need to do BMW keys and ecu swap this might make life more plesant
    Sent from my HUAWEI Y560-L01 using Tapatalk
    Ask a dumb question and become wise for the rest of your life, but act wise and stay dumb
    Apr 2010
    Hi.
    My xprog is version 5.0, does not renew the FRM, I will buy a new tool, but now I will wait for the launch of this tool and new opinions, maybe I will buy the updated xprog.
    Apr 2010
    Hi.
    I bought this tool now, it works well, it seems to me to be a reliable tool. I'm betting on this manufacturer.
    I have experience in mb, but bmw I have little experience, if anyone can help me with BMW FRM recovery.
    Nov 2014
    so far what did you work on with this tool
    Apr 2010
    HI.
    so I have no problem, but I only read 9s12, all normal, but the other tool mb cgdi I do not have success every time I try to extract passwords, I'm testing, but I think xhorse is better.
    Mar 2010
    Hi!
    Does it read HC908 based EZS(W203, W639) on-board? Worth its money? I've an old Xprog version + SKCcalculator and I'm thinking to do an upgrade with CDGI Prog MB & CG Pro 9S12. What is you opinion about it?
    Best Regards
    doctore's Avatar
    Nov 2015
    Colorado Denver
    Professional bmw key service cas 3/3+ 4/4+ repair = reset ews egs 8hp = 6hp-egs19d
  10. The Following User Says Thank You to doctore For This Useful Post:
    daxxer (9th May, 2018)
  11. #10
    Mar 2010
    Quote Originally Posted by doctore View Post
    What is the meaning of the dots?
  12. #11
    Nov 2016
    CG-Pro V1.3.4.0 NEW
    (2018.05.19)
    1. Add Key Matching
    Jaguar/Land Rover 3L40K
    2. Correction algorithm, Dashboard Mileage
    Benz EIS-639 (HC08)
    3. Fixed picture
    Audi A6L Q7 - J518 - 3L40K 4L40K 1L59W
    4. Optimize the part of the interface visual effect
  13. #12
    doctore's Avatar
    Nov 2015
    Colorado Denver
    any news abouth this tool can duet key from dump for cas3++ and cas4 or not
  14. #13
    Feb 2018
    Glasgow area
    Cas3++ definitely. I've done 9389115 all keys lost relatively straightforward using this and cgdi.
    I think cg pro can make the key without cgdi, but I'm not certain.
  15. The Following User Says Thank You to PixelsFixed For This Useful Post:
    doctore (21st September, 2018)
  16. #14
    dd1's Avatar
    Aug 2014
    HI everyone, would like to know if anyone has done cas3 OLO1Y mask???? with this tool. xprog, rosfar or upa wont. i can read but forget about programming. thank you in advance
  17. #15
    droidwayne65's Avatar
    Aug 2015
    North America
    Numerous times, with no problems.
