NEW CGDI FACTORY TOOL,
I would like to know if it will make FRM decript BMW and fix 9S12 9S12XEQ384 corrupt.
It will be better than your competitors XPROG and VVDI PROG.
Disable your caplock.
same here , I have been looking at it but at around $ 350 for it , it have some Benz functions and mostly BMW functions and a bit of other stuff I might be a nice add on to existing tools , but will it do what they say it can do , because I also need to do BMW keys and ecu swap this might make life more plesant
Sent from my HUAWEI Y560-L01 using Tapatalk
Ask a dumb question and become wise for the rest of your life, but act wise and stay dumb
Hi.
My xprog is version 5.0, does not renew the FRM, I will buy a new tool, but now I will wait for the launch of this tool and new opinions, maybe I will buy the updated xprog.
Hi.
I bought this tool now, it works well, it seems to me to be a reliable tool. I'm betting on this manufacturer.
I have experience in mb, but bmw I have little experience, if anyone can help me with BMW FRM recovery.
so far what did you work on with this tool
HI.
so I have no problem, but I only read 9s12, all normal, but the other tool mb cgdi I do not have success every time I try to extract passwords, I'm testing, but I think xhorse is better.
Hi!
Does it read HC908 based EZS(W203, W639) on-board? Worth its money? I've an old Xprog version + SKCcalculator and I'm thinking to do an upgrade with CDGI Prog MB & CG Pro 9S12. What is you opinion about it?
Best Regards
Professional bmw key service cas 3/3+ 4/4+ repair = reset ews egs 8hp = 6hp-egs19d
daxxer (9th May, 2018)
CG-Pro V1.3.4.0 NEW
(2018.05.19)
1. Add Key Matching
Jaguar/Land Rover 3L40K
2. Correction algorithm, Dashboard Mileage
Benz EIS-639 (HC08)
3. Fixed picture
Audi A6L Q7 - J518 - 3L40K 4L40K 1L59W
4. Optimize the part of the interface visual effect
any news abouth this tool can duet key from dump for cas3++ and cas4 or not
Cas3++ definitely. I've done 9389115 all keys lost relatively straightforward using this and cgdi.
I think cg pro can make the key without cgdi, but I'm not certain.
doctore (21st September, 2018)
HI everyone, would like to know if anyone has done cas3 OLO1Y mask???? with this tool. xprog, rosfar or upa wont. i can read but forget about programming. thank you in advance
Numerous times, with no problems.
