Page 1 of 7 123456 ... LastLast
Results 1 to 15 of 105
    Myjector's Avatar
    Dec 2017
    Default Vespa Primavera 50cc 2016 Models Mileage solution found
    Hi all,
    Just found out to change the mileage of an vespa primavera and some other simelar models.
    You will need following tool to read out: Renesas ez-Cube (you can get it on aliexpress)
    Read out the 64pin micro controller and there you can find the mileage and reprogramme it with this tool.
    It's just that, pin out you can find on the data sheet of R5F100
  2. The Following 11 Users Say Thank You to Myjector For This Useful Post:
    ampibali (13th July, 2022), Diagcar1 (6th June, 2018), johanw90 (21st November, 2019), jomberykaso (2nd September, 2018), Joxer (17th March, 2018), junmab (6th August, 2018), maremuruk (23rd April, 2022), Nicolas9 (4th August, 2018), pongsky (10th January, 2020), redje1100 (31st January, 2022), talk2idris (13th February, 2018)
  3. #2
    SxL'.xll's Avatar
    Oct 2017
    Flux island
    More info. Plz
    Envoyé de mon RNE-L21 en utilisant Tapatalk
    If i helped you then please click Thanks and Reputation Button
    Mar 2016
    I have several readings
    you will do the mileage
    you have a flash reading password
  5. The Following User Says Thank You to slawo1z For This Useful Post:
    SxL'.xll (5th August, 2018)
  6. #4
    SxL'.xll's Avatar
    Oct 2017
    Flux island
    Quote Originally Posted by slawo1z View Post
    Did you change the milege or not
    Aug 2018
    Hi which programmer u use to read????
  8. #6
    Mar 2016
    I trade and use jtag smok
    I can not calculate new KM
  9. The Following User Says Thank You to slawo1z For This Useful Post:
    pintu (16th September, 2018)
  10. #7
    Dr. Zoidberg's Avatar
    Oct 2015
    Talca-Chile.
    whats km do you need?
  11. #8
    Mar 2016
    I need
    3500 km
    4000 km
    4500 km
  12. #9
    sv2hqx's Avatar
    Jun 2014
    I need
    3500 km
    4000 km
    4500 km
    can you share how do you read?
  13. #10
    Mar 2016
    see screenshot
    select 1 and 2
    after read data flash is erase
    to read data flash no need pass
    pass need only to read flash
    someone knows password?
    I damaged one dash
    I've uploaded dataflash to flash
    eh....
    after 70 attempts there may be something wrong
    tiredness eh ....
  14. The Following User Says Thank You to slawo1z For This Useful Post:
    johanw90 (22nd November, 2019)
  15. #11
    sv2hqx's Avatar
    Jun 2014
    i know the solution from smok
    i thought first user read it with ez-cube
  16. #12
    Oct 2015
    Talca-Chile.
    3500 km
    Try it.....
    3500.rar
  17. #13
    gogalv's Avatar
    Aug 2010
    You can not even test! SC bad.
    You'll need pictures from all sides mate .... ? PremierD
  18. #14
    Moderator
    PremierD's Avatar
    Jun 2009
    Is that the same as the CS is bad mate
  19. The Following User Says Thank You to PremierD For This Useful Post:
    dashradio (31st March, 2022)
  20. #15
    Nov 2015
    Anyone have connections to power up this dash?
