Page 3 of 7 FirstFirst 1234567 LastLast
Results 31 to 45 of 105
  1. #31
    gogalv's Avatar
    Aug 2010
    bad.........
    You'll need pictures from all sides mate .... ? PremierD
  2. The Following User Says Thank You to gogalv For This Useful Post:
    Nicolas9 (16th September, 2018)
  3. #32
    Dec 2010
    vietnam
    Quote Originally Posted by gogalv View Post
    bad.........
    I have solution can bypass CS! Try my file on the dashboard before answering! Thank you!
  4. The Following User Says Thank You to hoangtu For This Useful Post:
    Nicolas9 (17th September, 2018)
  5. #33
    Nicolas9's Avatar
    Feb 2017
    Aruba
    Quote Originally Posted by hoangtu View Post
    could you change this file from 14884 km to 3650?
    UPDATE: thnx, hoangtu. i'll test in a few days
  6. #34
    Dec 2010
    vietnam
    3650km 50cc TEST!
  7. The Following User Says Thank You to hoangtu For This Useful Post:
    Nicolas9 (21st September, 2018)
  8. #35
    Nicolas9's Avatar
    Feb 2017
    Aruba
    3650km 50cc TEST!
    Didn't work unfortunately..
    Speedo stops at 12kmh.
    That's wierd. The donor file was fine, also from 50cc
    but thank you for your effort!
  9. The Following User Says Thank You to Nicolas9 For This Useful Post:
    dule14786 (11th April, 2023)
  10. #36
    Feb 2010
    Can you share a aliexpress link to order the tool.
  11. #37
    Feb 2016
    hello,
    what type of licence i need to select when i will buy the bdm jtag?
  12. #38
    Nicolas9's Avatar
    Feb 2017
    Aruba
    here i have two files of vespa primavera/sprint 50cc - tested! work ok
    2750km
    3700km
    pass protected.
    press thnx + reputation and send PM for pass
  13. The Following 6 Users Say Thank You to Nicolas9 For This Useful Post:
    Bm123 (13th May, 2020), CHIPTUNER030 (15th February, 2019), dule14786 (11th April, 2023), johanw90 (23rd September, 2019), Safety (26th April, 2019)
  14. #39
    Dec 2018
    heey I am new in this world. you might be able to explain to me what kind of products you use and how you used the products iwould like to learn things and I start with this
  15. #40
    Dec 2018
    Quote Originally Posted by jaed View Post
    hello,
    do you have the answer?
  16. #41
    Apr 2018
    EU
    Quote Originally Posted by Gisxzz View Post
    With all respect, this is not the one you want to start with if you are new kid on the block.
  17. #42
    Dec 2018
    Quote Originally Posted by Diagcar1 View Post
    what do you advise to start with
  18. #43
    Nov 2009
    Here are some more dumps with different km's
    i tested in red and blue display, 125cc and 50 cc.
    no problem at all.
    i'm making more low km files but it takes time
    no pass, please rep
    btw smok pinout:
  19. The Following 7 Users Say Thank You to r-parts For This Useful Post:
    CHIPTUNER030 (3rd January, 2019), Droidkiller (4th March, 2020), dule14786 (11th April, 2023), jarbo3a (24th January, 2023), Meat-Head (1st August, 2019), puiu (27th October, 2022), skens (21st April, 2022)
  20. #44
    Nicolas9's Avatar
    Feb 2017
    Aruba
    Quote Originally Posted by r-parts View Post
    no problem at all.
    no pass, please rep
    btw smok pinout:
    You cannot use 150cc on 50cc. Because the speedometer is different.
    50cc go to 80kmh
    150cc go to 140kmh
  21. #45
    Nov 2009
    i just did.
    works perfect, DATAflash ext don't determine the max speed, flash does.
    only the max pulse for upa is 0,151 for 50cc dash
