Results 1 to 14 of 14
Hybrid View
    koziolek's Avatar
    Feb 2010
    Under the car
    Default 2011 Mercedes C350 ME9.7 ECU renew needed
    2011 Mercedes ME9.7 ECU renew needed
    Can someone renew it please
    and is it possible to wright the file back with KTAG
    some people saying its only possible to read
    Nov 2009
    workshop
    upload flash
    koziolek's Avatar
    Feb 2010
    Under the car
    flash uploaded
    koziolek's Avatar
    Feb 2010
    Under the car
    Unfortunately can not write this file back with my KTAG clone ,
    its showing that is writing and process complete successfully but when i read again to verify the original file is there.
    I tried to write a few times with the same result
    huzefa's Avatar
    Jan 2010
    the KTAG read the eeprom two time
    when it
    writing its ok but when verify not ok
    If I helped please press rep + thanx
    huzefa's Avatar
    Jan 2010
    when it
    the org eeprom size 1.0kb
    but the ktag read it 4.0kb
    koziolek's Avatar
    Feb 2010
    Under the car
    can you clarify what you are saying? You mean that when I write it, it does it properly even though when I try to verify it says its wrong?
    huzefa's Avatar
    Jan 2010
    YES that what i say
  9. The Following User Says Thank You to huzefa For This Useful Post:
    koziolek (14th February, 2018)
  10. #9
    koziolek's Avatar
    Feb 2010
    Under the car
    So you sure I can do now drive authorization and it should start.
    how about vin number is still showing original vin from donor ,how it will change
    do I have to do on line SCN coding or not
  11. #10
    huzefa's Avatar
    Jan 2010
    if you whant i will send you zero file no vin
    you write it in eeprom 95080 by any programer like carprog or any tool
    but you have to remove the eeprom from ecu boord
    only eeprom you need
  12. The Following 2 Users Say Thank You to huzefa For This Useful Post:
    andreyvl (25th February, 2018), koziolek (15th February, 2018)
  13. #11
    koziolek's Avatar
    Feb 2010
    Under the car
    back to square one, ECU replace same errors there
    1200 ,0649, 0641, 0633
    when I erased errors they came back in a few seconds
    when I check live data in scanner exhaust camshaft sensor for bank one, the value does not change it looks like its frozen,
    The other 3 sensors acting in specification
    switch sensor position same result.
    check wire continuity all OK
    remove all camshaft sensors to check timing position all marks in center for both banks
    check with scope camshaft exhaust sensors for bank 1 and bank 2 .
    Bank 1 its yellow , Bank 2 its green
    bank 1 sends signal but when scan it ,scanner does not see any reading from that sensor frozen -20 .
  14. #12
    Jun 2013
    Poland
    Check balanser sprocket.
    Wysłane z mojego SM-G390F przy użyciu Tapatalka
  15. #13
    koziolek's Avatar
    Feb 2010
    Under the car
    ok but why no reading from exhaust camshaft sensor ?
  16. #14
    Jun 2013
    Poland
    i always when p1200 in m272 , disassemble right valve cover and endoscope look for balancer shaft
