Page 1 of 3 123 LastLast
Results 1 to 15 of 38
    M3L3R's Avatar
    Mar 2014
    Kolobrzeg
    Default Virgin file for elv bmw f30
    Hi!
    I virginized sh fem and adapted to car, then programmed new key. I need to do synch with fem->elv. Does someone have virgin elv 95040?
    rola1971's Avatar
    Jun 2014
    Dublin
    any news about reset?
    i need to same
    rola1971's Avatar
    Jun 2014
    Dublin
    any news?
    i have to same problem
    steering lock dead
    fem sleep
    z786's Avatar
    10 Steps Ahead of You
    Any updates on this?
    "I always tell the truth. Even when I lie"
    "We Taking Over, One City At A Time"
  5. The Following User Says Thank You to z786 For This Useful Post:
    Meat-Head (24th November, 2018)
    rola1971's Avatar
    Jun 2014
    Dublin
    Quote Originally Posted by z786 View Post
    if you need i have vigine file to elv
    please PM
    Apr 2016
    tested, works?
    rola1971's Avatar
    Jun 2014
    Dublin
    Quote Originally Posted by K1nd3r View Post
    tested, works?
    yes
    i have this problem and sorted
    z786's Avatar
    Does anybody have the process for teaching in a new elv?
  10. The Following User Says Thank You to z786 For This Useful Post:
  11. #9
    z786's Avatar
    Iv tried every option in icom but no luck
  12. #10
    drugowaz's Avatar
    Mar 2015
    Lithuania
    Write to rola. He offered you solution
  13. #11
    Europe
    rola has a virgin file. z786 supposedly has a new ELV and shouldn't need a virgin file. However, AFAIK you can only buy an entire new steering column so possibly it's still a second hand ELV?
  14. #12
    z786's Avatar
    It's a virgin file for dog but no option to code it in
  15. #13
    rola1971's Avatar
    Jun 2014
    Dublin
    my file 100% work
    i try and start car 100%
    my first problem i broke 95128 eeprom from fem and i buy second hand fem and key
    change isn and coding used vvdi2
    after all fiting to car after reflash car elv dead and car dont turn ignition
    i take out elv vrite new file
    and car start
    i dont know what need doit and where.for all reflash car and programming elv my help friend he used bmw icom but what program i dont know 100%
    but file work 100%
  16. The Following 3 Users Say Thank You to rola1971 For This Useful Post:
    doctore (16th May, 2018), helmov (21st December, 2020), z786 (16th May, 2018)
  17. #14
    z786's Avatar
    Yes your file did work because fault code changed. But new fault code was elv not taught in. Can u ask your friend what option he used to adapt it plz
  18. #15
    Europe
    Just use the search function in ISTA+. Go to Vehicle Management -> Troubleshooting -> Text search and search for ELV or Steering Lock. The type of result must be "ABL" (You can apply a filter or just check manually).
  19. The Following User Says Thank You to tomvleeuwen For This Useful Post:
