found eeprom 95256 , read it, here is the dump.
please clear for me if you know tested solution.
I think it will work, report back.
You use srs units files at your own risk. I am not responsible for any damages. Don't ask about passes, one file=one pass.
If I helped, please, use magic buttons reputation+thanks.
Best regards.
Dragon
please pass, thanks
Hi Mr. borshch .
I am work now with this airbag module but I try to clear DTCs via OBD2 and don't work.
Can you send the file and pass to probe this solution? because I don't know that if this hardware is good.
I know too that this is my second post but I hope to provide solutions to other friends when they need it.
Thanks.
Your cleared file.
Best regards.
Dragon
blackmeter (20th April, 2018)
Best regards.
Dragon
I write the file but airbag have a pretensor problem. Thank you very much Mr. Dragon100
First disconnect pretensioner and join resistor 2,2ohm and clear errors, if ok, then replace pretensioner and done ...
Best regards.
Dragon
Please help with crash file. Permanently stored "Crash" can't be cleared with Autel scanner.
Thank you!!
