Results 1 to 15 of 15
    Jul 2016
    USA
    Default 2016 Jeep Wrangler P68185855AB
    2016 Jeep Wrangler. airbag module part # P68185855AB.
    need crash cleared.
    in what mcu or eeprom is crash stored ?
    Jul 2016
    USA
    found eeprom 95256 , read it, here is the dump.
    please clear for me if you know tested solution.
    dragon100's Avatar
    Jan 2012
    From land of milk and honey
    I think it will work, report back.
    Best regards.
    Dragon
  4. The Following 2 Users Say Thank You to dragon100 For This Useful Post:
    borshch (13th February, 2018), compact (12th April, 2018)
    Jan 2014
    Michigan State USA
    Quote Originally Posted by borshch View Post
    Why you do not clear with scan tool first
    Jul 2016
    USA
    Quote Originally Posted by KALNAJJAR01 View Post
    dtc codes usually need to be cleared after clearing crash
    Jul 2016
    USA
    Quote Originally Posted by dragon100 View Post
    File worked. Thank you
    Feb 2012
    please pass, thanks
    Dec 2010
    Venezuela
    Hi Mr. borshch .
    I am work now with this airbag module but I try to clear DTCs via OBD2 and don't work.
    Can you send the file and pass to probe this solution? because I don't know that if this hardware is good.
    I know too that this is my second post but I hope to provide solutions to other friends when they need it.
    Thanks.
  10. #9
    Jul 2016
    USA
    Quote Originally Posted by blackmeter View Post
    Hi Mr. borshch .
    Thanks.
    post your original dump here and someone will help you clear crash.
  11. #10
    Dec 2010
    Venezuela
    This is My original dump
  12. #11
    dragon100's Avatar
    Jan 2012
    Your cleared file.
    Best regards.
    Dragon
  13. The Following User Says Thank You to dragon100 For This Useful Post:
    blackmeter (20th April, 2018)
  14. #12
    dragon100's Avatar
    Jan 2012
    Best regards.
    Dragon
  15. #13
    Dec 2010
    Venezuela
    I write the file but airbag have a pretensor problem. Thank you very much Mr. Dragon100
  16. #14
    dragon100's Avatar
    Jan 2012
    First disconnect pretensioner and join resistor 2,2ohm and clear errors, if ok, then replace pretensioner and done ...
    Best regards.
    Dragon
  17. #15
    slavax's Avatar
    Sep 2016
    Soyuz 1
    Default Please help with crash
    Please help with crash file. Permanently stored "Crash" can't be cleared with Autel scanner.
    Thank you!!
