So apparently it's 93c86s40
2016 Subaru. airbag module: 98221AJ24A (TN150300-8120).
(93c86 eeprom ?)
damaged original srs module. so got another srs module same part number from same model car.
scan tool shows dtc errors and airbag light is on.
trying to clear codes get error "Disgnostic Codes in Memory Cannot be cleared".
manufactured DENSO, its gonna be renesas mcu, it will work from another car
But this part number is eeprom 93c86
codes script need reset
98221AJ24A is from 2013 Subaru. Are you sure this is the correct module?
borshch (23rd February, 2018)
i found eeprom RA86, read it as 93C86, here is dump.
please check if there is crash in dump
sorry this car is 2012
presence of DTC codes.
Crash no in dtc .
possible module not compatible with your car
WINNER THE LOSER
1.Use this website http://www.worldoemparts.com/ to determine if this module is compatible with this car.
2.Clear ALL history faults, preferably with SSM3 or 4.
3.Make sure there is no other faults like ABS or ODS.
SRS light in Subarus usually goes OFF even if the "history" faults present but who knows.
Cheers
borshch (16th February, 2018)
Crash is for sure there, clear crash from it and all will be ok. Most likely will also need to clear crash from ODS unit in the seat also....
