Results 1 to 4 of 4
    Jan 2017
    Default John Deere premium hours
    Hi all, can john deere 6330 premium (command center) moto hours be corrected? Thanks all for help
    Eight's Avatar
    Bosnia and Herzegovina
    put your dump old and new moto hours
    Jan 2017
    Are hours located in command center or BCU or else where? Can't find any info on these tractors in other posts. Thanks
    Feb 2018
    Hours are located in ECU. With JD SA, you can only change hours up. If you have the ECU payload, you can reprogram it with an lost ECU procedure. Hours will be 0 then change it with SA with the number you want.
