Results 1 to 8 of 8
    alexandrosts's Avatar
    Feb 2017
    there where civilization started
    Default 2009 renault megane 1.6lt gasoline need hepl
    hi i have this 2009 Renault megane with the 1,6;t gasoline engine and i have this fault that has pop up on the cluster injectors a controller fault, and the car it wont do nothing no crank nothing at all
    please if anyone has had the same issue help me out i need this car gone from the shop
    Jul 2013
    yorkshire
    Check fuses/links on battery terminal <carfully>
    Feb 2017
    thanks for help.
    I actually did checked the fuses and the terminals as well, i actually pulled a fuse at some point and the vehicle came back to life it worked for a day and then the next day same problem
    when the injector a controller comes on i cant even crank the car i did try to start it from the starter solenoid it cranks but does not run
    Louislesinge's Avatar
    Jun 2017
    French Jungle
    Tell us, when you put your card into the reader, have you got a message?
    In case did you try to help the card reading with knife inserted with the card?
    Does steering unlock?
    Regards,
    Feb 2017
    yes when you insert the card in car powers up normally and steering unlocks properly and steering works it just poops the message injector a controller and it wont let me crank and start it
    Feb 2016
    sveden
    what is felcode
    Jul 2013
    yorkshire
    Is the battery good? When you press start do the dash light go out. Have you checked the clutch pedal swich. Why did it start after removal of a fuse? that may be your start point.
    Jun 2017
    French Jungle
    Ok, I see, for this problem you will need to check the ECU with a diagnostic tool, otherwise we can't help you.
    Waiting for DTCS.
    Regards,
