Ctroen ds4 ecu
Results 1 to 4 of 4
Thread: Ctroen ds4 ecu
    AutoGeek's Avatar
    Jul 2016
    Northern Cape,South Africa
    Default Ctroen ds4 ecu
    Hie guys. i need help with a Citroen with MED17.4.2 ECU,the old on packed up and i got a donor module.Now matching it with the BCM requires a pin code which i cannot read from the old module since its dead. i am using hex edit to input the vin lines,the BCM codes but i dont have the pin for final adaptation?anybody help here?Citroen DS4 2011 according to the the vin (VF7NX5FU8CY561956)?
    Aug 2012
    BALTIC
    Quote Originally Posted by samoosa1 View Post
    so you have new virgin ecu and need pin learn ecu?
    AutoGeek's Avatar
    Jul 2016
    Quote Originally Posted by seattm2012 View Post
    yes boss,need to learn the new ecu
    Nov 2011
    If you have bsi dump than post it here.
    Sent from my Nexus 5X using Tapatalk
