Results 1 to 4 of 4
Thread: ecu problem
    Default ecu problem
    Hello
    I have a 2010 passat 1.6 cayc engine pcr2.1 ecu.
    It is a non runner with no injector pulses.All injectors
    have been tested and were found to be ok fuel pressure is ok The loom is also
    ok The only fault I am getting is P214600.I think the problem
    is with the ecu and if so is there a way to repair it.I would
    be very grateful for any help.
    Larry.
    Pyromaniak's Avatar
    Aug 2015
    ~~~~ing CZECH
    test unplug one injector and try start. try with other one if no start. if start, unpluget injector is bad.
    Injector when go death, go to short cicruit, car not start and this dtc coming.
    My English is little bit bad, but day after day is better. Like my experiences https://www.youtube.com/channel/UCdT...bx2Pc7WI4pWUWA
    My help not for free, press THANKS and REP, for make me HAPPY
    im not using passwords, my work is for this forum and members free
    Hello
    Yes I have tried disconnecting injectors one at a time and car still wont start.
    Get used ecu, flash frf file of current ecu to your used ecu. Get someone to adapt with geko remotely.
