Hi, try and report.
Hi, try and report.
Best regards.
Dragon
Thanks Dragon, but it does not work
with your clear not
he does not even
diagnosis connection
You have xentry I see, then do clear via xentry ...
Best regards.
Dragon
I do not think I can do
car first remained in the garage repair
authorized mercedes for a week
I havent das xentry but I think you should try developer mode ...
Best regards.
Dragon
Zeroing the first part
the diagnosis mercedes recognizes ecu
like virgin
and allows reflash with SCN encoding
but I do not have
password mercedes
I am not authorized
Someone has some ideas
Hello guys,
I have this airbag module from Mercedes ML W166 with Bosch part number 0 285 011 136 and it is having the fault B220700 which means internal fault.
Attached is the dump of the eeprom 95128, maybe someone can help me with this.
Thank you,
