Results 1 to 3 of 3
Thread: I-shift
    USA
    Default I-shift
    HI
    I have 2015 Volvo VN that is being repaired after accident,unable to crank engine,did not tried to bypass to try start because viscous fan is damaged and need to be remove it first!!!
    put shop air to get air pressure in system
    transmission makes shifting noise when try to go to "R" or "M"
    Used Jpro For Diagnostic
    there is one active code in TCU
    I-shift model is ATO2612D
    P10AE81 Engaged Gear in Neutral - Invalid Serial Data Received
    So far I was unable to find out how to trouble shoot this malfunction
    Any one have info about this code?
    Oct 2018
    Hello i keep getting the same code after truck is parked for an hour. Did u ever resolve ur issue?
    Hi Mate,
    This is a software related issue. Please ask an official dealer to update your TECU Software. It could also be a hardware issue but I recommend to start with a software update as it is the least expensive solution
