I got a Chinese clone diagnostic tool to be able to diagnose fault codes of my KIA Ceed.
The board I got has a seperate PCB with the relays.
Here is my board.
I installed wow and delphi. After connecting, it informed me that I should update the firmware so I dit it. The firmware that was installed by wow was 1423. After that I was able to connect with my car and start diagnosis.
The problem is that it cannot communicate with ABS on my 2008 KIA Ceed.
I performs checks on all the other systems (including SRS), but on ABS wow reports: "Assemply does not respond"
I tried on a second car (Hyundai Accent 2001) and it performed all checks successfully.
I tried delphi after copying the firmware from wow folder to delphi. It was able to perform other checks but again it wasn't communicating with ABS. I also tried to update the firmware with 1430 but it didn't help.
While it performs the ABS scanning, the relay is clicking, the led switches between blue and green for a longer time period, which probably means that it doesn't get any response from the car.
What should I check on my board and/or my car? I am able to unsolder/solder parts but I don't know what to check on the boards.
I don't know how the scanner communicates with each system and what causing it to fail with ABS so I am not sure if this is a hardware, firmware, software issue or a problem with my car.
A few weeks ago the ABS light was on and that was the main reason I bought this board, so I would really like to find the issue and fix it. I visited a local garage, they replaced a part and they scanned and clear the fault code using a genuine tool with wow.
