Hello
Sorry for english
I did hsa and dds retrofit nomally i never found hsa and dds supported a car upwards 2011 as you know opel changed the abs socket after 2009 and i couldn t find abs ecu which supported hsa and dds on z13dtj. i bought a old socket abs ecu. A friend help me about VIN for sps programming so only thing how to do converter between old abs ecu socket and new abs ecu socket i made it within 1 day..so it worked very well no DTC.. but i got new problem central auto lock was not working regular but it s strange auto central lock is working sometimes or not as you know it s activating after 10 km/h...even stop engine and restart it s not working.. I have also touch and connect so it was working on ignition 1 but it s not working on ignition 1 anymore it works in ignition 2 after stop the engine t&c is also turning off(
what i have done maybe you can give me an idea about issue...
1) esp retrofitted with new socket(everthing was ok)
2) after replace old ecu with my converter tool , i didn t realize but it was working central lock and ignition 1 radio problem.. maybe i remember wrong
3) i changed the hazard switch because of dds button maybe i thought problems is hazard switch and i changed it with old one but no luck it s same problem it was not working..
4) i thought maybe problem is BCM i replaced the old one but ignition problem continues i couldn t check auto door lock system because i had to program it again..
5) I replaced with new socket old abs module nothing change, radio ignition problems continues(
6) All functions are working very well except these radia ignition and auto lock problems
7) How corsa read data for central lock when you drive after 10 km/h?
i don t have any DTC it s clear but i have these problems What do you think about that ??
